Hey guys, first of all loving Pi-Hole so far - but I am a sucker for graphs and data, which is where I'm struggling a bit:
Searching slices of the the Long Term Data via webinterface shows beautiful visualized data for body and soul to enjoy.
"Error Connecting to Database" upon opening the "Query Log". "Graphics" and "Top Lists" present no data upon query, simply wheels that spin forever.
Querying the .db with the example from the documentation works as expected it seems:
https://tricorder.pi-hole.net/9f7pzgv54j!
Attempted Steps:
I've run "sudo chown -R pihole /etc/pihole/"
Multiple restarts done
pi@noads:~ $ ps -o fname,user -p $(pidof pihole-FTL)
COMMAND USER
pihole-FTL pihole
pi@noads:~ $ ps -o fname,user -p $(pidof lighttpd)
COMMAND USER
lighttpd www-data
pi@noads:~ $ stat /etc/pihole/pihole-FTL.db
Access: (0644/-rw-r--r--) Uid: ( 999/ pihole) Gid: ( 996/ pihole)
Try:
sudo chmod +r /etc/pihole/pihole-FTL.db
But by running the chown
recursively (-R
), you changed ownership of all files contained in that folder:
pi@noads:~ $ ll /etc/pihole/
total 240276
drwxr-xr-x 2 pihole pihole 4096 Apr 22 20:37 .
drwxr-xr-x 101 root root 12288 Apr 20 08:38 ..
-rw-r--r-- 1 root root 507 Aug 31 2018 adlists.list
-rw-r--r-- 1 root root 759 Jun 8 2018 adlists.list.old
-rw-r--r-- 1 root root 29 Apr 21 04:22 black.list
-rw-r--r-- 1 root root 29 Dec 27 2017 blacklist.txt
-rw-r--r-- 1 pihole pihole 493 Apr 22 20:19 dhcp.leases
lrwxrwxrwx 1 root root 14 Aug 16 2018 dnsmasq.d -> /etc/dnsmasq.d
-rw-r--r-- 1 root root 18 Apr 22 16:28 GitHubVersions
-rw-r--r-- 1 root root 2970555 Apr 21 04:22 gravity.list
-rw-r--r-- 1 root root 1358 Apr 20 08:38 install.log
-rw------- 1 root root 1140100 Apr 21 04:22 list.0.raw.githubusercontent.com.domains
-rw------- 1 root root 595976 Apr 20 08:39 list.1.mirror1.malwaredomains.com.domains
-rw------- 1 root root 638705 Apr 20 08:39 list.2.sysctl.org.domains
-rw------- 1 root root 7295 Apr 20 08:39 list.3.zeustracker.abuse.ch.domains
-rw------- 1 root root 613 Apr 20 08:39 list.4.s3.amazonaws.com.domains
-rw------- 1 root root 43642 Apr 20 08:39 list.5.s3.amazonaws.com.domains
-rw------- 1 root root 1772428 Apr 20 08:39 list.6.hosts-file.net.domains
-rw------- 1 root root 18525 Apr 21 04:22 list.7.dehakkelaar.nl.domains
-rw------- 1 root root 395154 Apr 21 04:22 list.8.gitlab.com.domains
-rw-r--r-- 1 root root 2970572 Apr 21 04:22 list.preEventHorizon
-rw-r--r-- 1 root root 20 Apr 22 20:30 localbranches
-rw-r--r-- 1 root root 42 Apr 21 04:22 local.list
-rw-r--r-- 1 root root 39 Apr 22 20:30 localversions
-rw-r--r-- 1 root root 234 Apr 20 08:38 logrotate
-rw-rw-r-- 1 pihole pihole 0 Aug 8 2018 pihole-FTL.conf
-rw-r--r-- 1 pihole pihole 235388928 Apr 22 20:37 pihole-FTL.db
-rw-rw-r-- 1 pihole www-data 0 Aug 8 2018 regex.list
-rw-r--r-- 1 root root 529 Apr 20 08:59 setupVars.conf
-rw-r--r-- 1 root root 527 Apr 20 08:38 setupVars.conf.update.bak
-rw-r--r-- 1 root root 236 Aug 21 2018 whitelist.txt
system
Closed
3
