Please ensure that you are running the latest version of the beta code.
Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Problem with Beta 5.0:
Question only as there is no functionality that is not working. I noticed that under the settings in the web GUI blocklists are called Blocklists and then in the new Groups options they are called Adlists. The new gravity.db also is based on the new term adlists.
Is this a carryover from something? Is there a reason they are different? If not, is there a preference on which one is used. I am not a programmer by any means but would be willing to make an attempt at making the term consistent if it is desired.
