I make any change through the web interface and after I hit save the page refreshes and the change is shown.
I make a change, ie DNS upstream servers or click Whitelist box, hit Save after screen refreshes the change has not taken affect. No changes made.
[i] Adding home-lab.com to whitelist...
[i] home-lab.com does not exist in blacklist, no need to remove!
[i] Using cached Event Horizon list...
[i] 114654 unique domains trapped in the Event Horizon
[i] Number of whitelisted domains: 1
[i] Number of blacklisted domains: 0
[i] Number of regex filters: 0
[✓] Parsing domains into hosts format
[✓] Cleaning up stray matter
[✓] Force-reloading DNS service
[✓] DNS service is running
[root@localhost ~]#
The logs from Aug 13 are right after I tried to make a change thru web UI.
[root@localhost ~]# journalctl -u lighttpd --full --no-pager
Aug 09 08:46:06 localhost.localdomain lighttpd[4034]: sudo: sorry, you must have a tty to run sudo
Aug 09 08:46:15 localhost.localdomain lighttpd[4034]: sudo: sorry, you must have a tty to run sudo
Aug 13 09:32:23 localhost.localdomain lighttpd[4034]: sudo: sorry, you must have a tty to run sudo
[root@localhost ~]#
