Web Interface Inaccessible from Desktop PC
I want to be able to access the web interface through my desktop PC using pi.hole/admin.
The page times out in Firefox, IE, and Edge when trying to access pi.hole/admin or piholeip/admin. On my smartphone and laptop, I'm able to reach it through pi.hole/admin.
https://tricorder.pi-hole.net/r61a66rdmh
I'm using a WR841N router flashed to DD-WRT. I can see that PiHole is working as a DNS resolver by looking at the logs on my phone. I thought this was possibly the issue. Apparently, older versions of DD-WRT have an issue with ethernet ports. This did not help, and now I'm having to set the DNS for my PC in the network adapter properties or I get a weird Windows could not detect proxy settings error. Other devices work, but now I have to set another DNS at adapter level for my desktop PC.
curl -I pi.hole from my PC produces:
PC>curl -I 192.168.1.102
curl: (7) Failed to connect to 192.168.1.102 port 80: Timed out
PC>curl -I pi.hole
curl: (6) Could not resolve host: pi.hole
From the Pi:
HTTP/1.1 200 OK
X-Pi-hole: The Pi-hole Web interface is working!
X-Frame-Options: DENY
Set-Cookie: PHPSESSID=9504iju70ih66dc2cq1uj6hke1; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Date: Wed, 24 Jul 2019 05:48:29 GMT
Server: lighttpd/1.4.45
Edit: I got it working. The problem was with DD-WRT.
Solution was in running some commands on my router. Issue for DD-WRT on some routers where ethernet devices have issues communicating to wireless?
swconfig dev switch0 set reset 1
swconfig dev switch0 set enable_vlan 1
Pi-hole is not a proxy.
You should be setting it as a DNS server in either your router settings OR manually in the network settings of each device.
Your setup as you've described it would be expected to fail as windows can't resolve pi.hole unless the Pi-hole is your DNS server
I wrote that incorrectly. It was set as the DNS in the network adapter settings. I'm still unable to access the web interface from my desktop PC.
From the desktop PC, what are the outputs of the following commands from the PC terminal:
nslookup pi.hole
ipconfig /all
nslookup pi.hole
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.102
ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : i36300
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : hsd1.tx.comcast.net
Ethernet adapter VirtualBox Host-Only Network:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter
Physical Address. . . . . . . . . : 0A-00-27-00-00-06
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::f1ca:b093:668f:6009%6(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.96.9(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 403308583
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-1D-01-C8-4C-CC-6A-6B-69-FA
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : hsd1.tx.comcast.net
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 4C-CC-6A-6B-69-FA
Link-local IPv6 Address . . . . . : fe80::35d7:d715:9047:6b7f%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.112(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, July 24, 2019 5:53:55 PM
Lease Expires . . . . . . . . . . : Thursday, July 25, 2019 6:04:41 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 72141930
DNS Servers . . . . . . . . . . . : 192.168.1.102
On the desktop PC, the internet doesn't work at all when its DNS server is set 192.168.1.102. I thought it was earlier, but I must not have had the DNS set to the pihole.
So it appears my desktop PC can't see the pihole, but other devices on the network can.
Edit: I am able to SSH and ping the pihole from the desktop. Although ping only works with the name of the device, not the IP address.
I agree that is the case. Since other devices can communicate with Pi-Hole for DNS, this makes it a configuration problem on that PC. I would go to some of the Windows forums and see if there is a solution there.
Your debug log shows that Pi-Hole is working normally.
Okay, I'll try there too.
