Hello. When visiting the admin console, I am having an issue where the title logo / donate button block the view of the console. I have run the repair, but this hasn't resolved the issue.
The administration page used to load without issue
The last couple of weeks, the donate button has obscured the page.
Image of admin on Safari/iPhone. Viewing it on a laptop has the same issue. Image
I'm not able to connect a keyboard/screen to the pi at the moment, so I can't have a look at the dev tools using F12. The device is tucked away in the closet and connected to an ADSB antenna (aircraft tracking).
Ok, I've installed TightVNC and now have access to the Remote Desktop. I don't have much experience here, I'm having trouble getting the dev tools open.
You do not have to connect to the Pi's screen to open the dev tools. Simply open the web interface up on another computer and open the dev tools (F12, or on Mac, right click -> inspect element)
The visual error is caused by not being able to load that script. Go to the network tab in the dev tools (you may need to reload the page) and find the request that fails. Share the request/response data.
I did try other devices and other browsers, with the same result.
Yesterday the pi-hole admin page started displaying correctly again (I didn't do anything to it). So... it works now! Thanks for your responses and suggestions, I appreciate your time.
