Yes, I tried it twice and same results, which is why I'm glad I set up an adlist for netflix, if you'd like a list, I can just post it here.
Well, that's basically what I'm going to do anyway with the logs, so I pulled power, plugged in, and waited for the device "smart" tv to boot for about 30 seconds or so.
Roku stuff started first, and then this:
Edit: Since there is only one, I just fugured it is related / needed for another service but I think apple streaming is also preloading too.
2022-07-16
13:54:10 A cdn-0.nflximg.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:54:10 A cdn-0.nflximg.com 192.168.1.21 Blocked (gravity) IP (0.2ms)
2022-07-16
13:54:08 A occ-0-1328-1327.1.nflxso.net 192.168.1.21 Blocked
(exact blacklist) IP (0.0ms)
2022-07-16
2022-07-16
13:54:04 A self.events.data.microsoft.com 192.168.1.21 Blocked
(exact blacklist) IP (0.1ms)
2022-07-16
2022-07-16
2022-07-16
13:54:03 A nrdp51-appboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:54:03 A nrdp51-appboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.2ms)
2022-07-16
13:53:58 A ichnaea.netflix.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:50 A nrdp50-appboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
13:53:50 A nrdp50-appboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:48 A cdn-0.nflximg.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
2022-07-16
13:53:48 A uiboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
2022-07-16
13:53:47 AAAA api.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:47 AAAA api.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
13:53:47 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
2022-07-16
13:53:43 A preapp.prod.partner.netflix.net 192.168.1.21 Blocked
2022-07-16
(exact blacklist) IP (0.7ms)
2022-07-16
13:53:43 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
13:53:43 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:42 A occ-0-1328-1327.1.nflxso.net 192.168.1.21 Blocked
2022-07-16
(exact blacklist) IP (0.5ms)
2022-07-16
13:53:39 AAAA push.prod.netflix.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:39 A push.prod.netflix.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:38 A push.prod.netflix.com 192.168.1.21 Blocked
2022-07-16
(exact blacklist) IP (0.6ms)
2022-07-16
13:53:28 A nrdp50-appboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:28 A nrdp50-appboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.4ms)
2022-07-16
13:53:26 A nrdp.prod.ftl.netflix.com 192.168.1.21 Blocked
2022-07-16
(exact blacklist) IP (0.4ms)
2022-07-16
13:53:26 A cdn-0.nflximg.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
2022-07-16
13:53:26 A ichnaea.netflix.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:26 A customerevents.netflix.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:26 A uiboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:26 A uiboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.8ms)
2022-07-16
13:53:26 A secure.netflix.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:26 A secure.netflix.com 192.168.1.21 Blocked (gravity) IP (0.6ms)
2022-07-16
13:53:26 A api-global.netflix.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:26 A nrdp.nccp.netflix.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:26 A nrdp.nccp.netflix.com 192.168.1.21 Blocked (gravity) IP (0.7ms)
2022-07-16
13:53:26 A nrdp51-appboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:26 A nrdp51-appboot.netflix.com 192.168.1.21 Blocked (gravity) IP (0.5ms)
2022-07-16
13:53:26 AAAA scribe.logs.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:26 AAAA scribe.logs.roku.com 192.168.1.21 Blocked (gravity) IP (0.2ms)
2022-07-16
13:53:26 A scribe.logs.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
13:53:26 A scribe.logs.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:25 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
2022-07-16
13:53:21 A lat-services.api.data.roku.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:19 AAAA mediaservices.cdn-apple.com 192.168.1.21 Blocked
2022-07-16
(exact blacklist) IP (0.3ms)
2022-07-16
13:53:19 A mediaservices.cdn-apple.com 192.168.1.21 Blocked
2022-07-16
(exact blacklist) IP (0.9ms)
2022-07-16
13:53:17 A customer-feedbacks.web.roku.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:16 AAAA scribe.logs.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
13:53:16 AAAA scribe.logs.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:16 A scribe.logs.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
13:53:16 A scribe.logs.roku.com 192.168.1.21 Blocked (gravity) IP (0.8ms)
2022-07-16
13:53:11 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:11 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
13:53:07 AAAA api.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
2022-07-16
13:53:07 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
2022-07-16
13:53:05 A configsvc.cs.roku.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:53:03 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.2ms)
2022-07-16
13:53:03 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:53:01 A api.rokutime.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:52:59 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
2022-07-16
13:52:57 A api.rokutime.com 192.168.1.21 Blocked
(exact blacklist) IP (0.2ms)
2022-07-16
2022-07-16
13:52:55 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.1ms)
2022-07-16
13:52:55 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.2ms)
2022-07-16
13:52:53 A api.rokutime.com 192.168.1.21 Blocked
2022-07-16
2022-07-16
13:52:50 A api.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
2022-07-16
13:52:49 A api.sr.roku.com 192.168.1.21 Blocked (gravity) IP (0.0ms)
2022-07-16
13:52:49 A api.sr.roku.com 192.168.1.21 Blocked (gravity) IP (0.2ms)
2022-07-16
13:52:49 A api.rokutime.com 192.168.1.21 Blocked
I didn't even turn on the display! So far, for the rest of the streaming services, they, again for now, don't auto start, but who knows how long that will be? So when I want to watch netflix, I disable the block list, no matter what domains they use, I'll adapt every single day if necessary. Frankly, where does it say in the "license agreement" or "privacy" policy that I am allowing the service to start at its own discretion? I'm sure it's in there somewhere, so I'm letting you all know if you missed it in your logs.
