Problem with Beta 5.0:
Receiving error from Browser DataTables warning: table id=network-entries - Requested unknown parameter 'ip' for row 0, column 0. For more information about this error, please see http://datatables.net/tn/4
when I go to the network page.
https://tricorder.pi-hole.net/twbqdkyews
I'm running this on a Raspberry Pi2b and had some problems with the upgrade ie. I copied the commands to switch to the beta and just ran them as is without inserting any &&
between the lines on the assumption the line breaks would be okay and ran face first into core not updating properly and pihole-ftl refusing to resolve DNS. I went and manually modified /etc/resolv.conf to use 8.8.8.8 and then went back and re-ran pihole checkout core release/v5.0
and that appeared to have fixed me up. When I then went to go into the web UI I received an error about /etc/pihole/adlists.list being unavailable. So I went back to the terminal and ran sudo touch /etc/pihole/adlists.list
and that solved that issue. Now I'm just left with this error when I go to use the network page.
