I had a fairly large whitelist that I compiled over a year or two. I ran pihole -up and was excited to see that 5.0 is GA now
I now see that my previous whitelist was "Migrated from /etc/pihole/whitelist.txt" and expected everything to work as it used to
Ubuntu 16.04.06 LTS
Whitelist is not working.
Items that were previously in the whitelist now show up in the query log as "Status : Unknown (9)"
I have to slowly rebuild my lists
Is there somewhere I can get my old list from?
EDIT - I found the old whitelist in /etc/pihole/migrated_backup
Is there a quick way that I can add multiple domains into the new whitelist and not one by one?
EDIT 2 - rebooted the machine, no joy
E.G
Query log:
The "Unknown" message relates to your browser caching an older version of the dashboard which is not yet aware of this new status. It will not help immediately, however, it will show better what is going on!
v5.0 ships something called "deep CNAME inspection". Update your dashboard and it will give you more information.,
What do you see now for the whitelist? Am I right assuming you added extra adlists blocking more than what the developers offer during the regular install?
Pi-hole v5.0 does this "deep CNAME inspection". Before, you had to block "facebook.com" to prevent access. Now, if there are redirections in between, these domains are also checked. It is likely that these additional checks prevent access to this pages for you. You should be seeing what was blocked exactly now in the Query Log after having cleared your cache.
I have had to add some newer entries that were on my previous list.
I do have "non-standard" block lists added, but have not added/removed any lists since the update
Yes I understand the new CNAME inspection method, but I also understand that whitelist is always checked first - so many domains should already be allowed. But they are blocked from gravity
The file was possibly corrupt, as it was being read as a binary file...
Might want to check the quality of your SD card or make sure the power supply you use on your Pi is properly rated for that hardware. (Or, if you're not using a pi / SBC ignore that comment!)
Okay, this was not clear so far. You only said whitelist is not working. You never said there was only one entry there. So I assumed your domains were all present just not applied which is I was looking for reasons why a whitelisted domain could be blocked.
Glad that this is resolved now using the powers of Mr. @PromoFaux.
