Updated Pihole - Web Interface Version is now N/A
UPDATE : https://tricorder.pi-hole.net/wBJtgYdF/
Dietpi Base - Updated to DietPi v8.8.
Updated Pihole via pihole - up
The web interfce now shows all versions as N/A, and when checking pihole -v it shows there is a update -
AdminLTE version is v5.13 (Latest: v5.14)
But when updating it says its current.
Any obvious reason this is happening?
NA
pihole updTE
[i] Remotes: origin	https://github.com/arevindh/AdminLTE (fetch)
             origin	https://github.com/arevindh/AdminLTE (push)
You're not using our web repo....
Edit: ah, it's the speedtest mod. You'll need to ask them for support on GitHub..)
