Hey, im from German and my English is not so good...
My Problem: The Update does not work..
Anyone can help me?
login as: root
root@84.200.7.189's password:
Welcome to Ubuntu 14.04.5 LTS (GNU/Linux 2.6.32-openvz-042stab123.3-amd64 x86_64)
Documentation: https://help.ubuntu.com/
Last login: Sun Jul 9 23:52:43 2017 from dslb-178-000-244-150.178.000.pools.vodafone-ip.de
root@srv46919:~# sudo pihole -up
::: Checking for updates...
::: Pi-hole Core: update available
::: FTL: up to date
::: Web Interface: up to date
::: Pi-hole core files out of date
::: Checking for existing repository...
::: Updating repo in /etc/.pihole... done!
done!.;;,. .ccccc:,. :cccclll:. ..,, :ccccclll. ;ooodc 'ccll:;ll .oooodc .;cll.;;looo:. .. ','. .',,,,,,'. .',,,,,,,,,,. .',,,,,,,,,,,,.... ....''',,,,,,,'....... ......... .... ......... .......... .......... .......... .......... ......... .... ......... ........,,,,,,,'...... ....',,,,,,,,,,,,. .',,,,,,,,,'. .',,,,,,'. ..'''.
::: You are root.
::: --unattended passed to install script, no whiptail dialogs will be displayed
::: Verifying free disk space...
::: Updating local cache of available packages... done!
::: Checking apt-get for upgraded packages.... done!
::: There are 11 updates available for your system!
::: We recommend you update your OS after installing Pi-hole!
::: Checking for apt-utils... installed!
::: Checking for dialog... installed!
::: Checking for debconf... installed!
::: Checking for dhcpcd5... installed!
::: Checking for git... installed!
::: Checking for iproute2... installed!
::: Checking for whiptail... installed!
::: --reconfigure passed to install script. Resetting changes to local repos
::: Resetting repo in /etc/.pihole... done!
::: Resetting repo in /var/www/html/admin... done!
::: Checking for bc... installed!
::: Checking for cron... installed!
::: Checking for curl... installed!
::: Checking for dnsmasq... installed!
::: Checking for dnsutils... installed!
::: Checking for iputils-ping... installed!
::: Checking for lsof... installed!
::: Checking for netcat... installed!
::: Checking for sudo... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for lighttpd... installed!
::: Checking for php-common... installed!
::: Checking for php-cgi... added to install list!
Unable to complete update, contact Pi-hole
root@srv46919:~#
End
Thank,
Leon
