(I reformated your post for better readability)
Dig returned sucessfully the list of supported OS. So the installe should not fail silently.
Please try
curl -sSL https://install.pi-hole.net | PIHOLE_SKIP_OS_CHECK=true sudo -E bash
Please try
root@chris:/home/chris# curl -sSL https://install.pi-hole.net | PIHOLE_SKIP_OS_CHECK=true sudo -E
usage: sudo -h | -K | -k | -V
usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command]
usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p prompt] [-T timeout]
[-u user] [VAR=value] [-i|-s] [<command>]
usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p prompt] [-T timeout]
[-u user] file ...
curl: (23) Failed writing body (1354 != 1371)
Failed I am afraid.
The bash was missing.
I am an idiot missing the bash!
Loads but not as it should.
DataTables warning: table id=messagesTable - Invalid JSON response. For more information about this error, please see http://datatables.net/tn/1
Might be why it's unsupported, but I don't know offhand.
Please generate a debug token with pihole -d or via the web interface. If time permits, a moderator might have a look into your issue.
Unsupported means unsupported.
If you want to post the contents of the debug here, then that's fine. But developer's won't be looking at the logs.
Many thanks for suggestions made.
I did:
sudo su
PIHOLE_SKIP_OS_CHECK=true pihole -up
And it worked.
Great news, Can I assume that relied on you having Ver 4 running and was not a fresh install of 5?
No, I upgraded from v5.0 to v5.1
(Armbian Bionic, BPi M2U)
Thanks. This installed PiHole on Armbian on my Odroid XU4.
i am getting an error :
Could not resolve host: install.pi-hole.net
anybody gets the same message?
This.
Pihole went on to check update but it stopped on downloading and installing FTL:
[✓] Detected x86_64 architecture
[i] Downloading and Installing FTL...curl: (6) Could not resolve host: github.com
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-linux-x86_64 not found
[✗] FTL Engine not installed
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1 to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Run the long form updater again.
