Hello,
I use pi hole with unbound, but it suddenly stopped working after I replaced my router firmware with openwrt.
I'm not fully sure how this is related, but my pihole dhcp works, and dns also works while using cloudflare. But while using unbound it doesn't resolve any domains.
https://tricorder.pi-hole.net/v4UvcSCB/
jfb
August 31, 2022, 10:08pm
2
What is the output of the following command from the Pi terminal:
> pi@raspberrypi:~ $ sudo grep -v '#\|^$' -R /etc/unbound/unbound.conf*
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf: auto-trust-anch or-file: "/var/lib/unbound/root.key"
/etc/unbound/unbound.conf.d/pi-hole.conf: verbosity: 0
/etc/unbound/unbound.conf.d/pi-hole.conf: interface: 127.0.0.1
/etc/unbound/unbound.conf.d/pi-hole.conf: port: 5335
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip4: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-udp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-tcp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: prefer-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-glue: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-dnssec-stripped: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: use-caps-for-id: no
/etc/unbound/unbound.conf.d/pi-hole.conf: edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/pi-hole.conf: prefetch: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: num-threads: 1
/etc/unbound/unbound.conf.d/pi-hole.conf: so-rcvbuf: 1m
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 192.168.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 169.254.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 172.16.0.0/12
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 10.0.0.0/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fd00::/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fe80::/10
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: name: "."
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: forward-addr: fda3:1225: a34e::1
pi@raspberrypi:~ $
jfb
August 31, 2022, 10:18pm
4
I assume these forwarding lines were not installed by you?
This has your unbound configured to send all DNS queries to your Pi-hole, it appears. This is an endless loop.
[✓] www.amphibiousvehicle.eu is :: on eth0 (fda3:1225:a34e:0:7493:fe3b:fd77:74c2)
Remove this configuration file and restart unbound. If your OS is auto-populating the file, find the source and get rid of that.
In Raspbian Bullseye (as one example) the source is /etc/resolvconf.conf
No I didn't add those line, but removing the file and restarting unbound helped.
The file wasn't generated again.
I had DHCPv6 enabled on openwrt for a short while, this might has messed something up.
But now it's working again, thanks.
system
Closed
September 21, 2022, 10:30pm
6
