Unbound on buster
Have run pihole for a while. Recently installed unbound following the instructions at unbound - Pi-hole documentation and pihole, dig etc all apparently work fine. The target Pi runs Rasbian Buster, so I didn't do the Disable resolvconf.conf bit at the end as I thought it wasn't applicable.
Working DNS resolver.
Working DNS resolver, BUT the /etc/resolv.conf file contains nameserver 127.0.0.1 without a 5335 port, which I understood from the article to be the symptom of the confg error. Should I worry about this?
N/A
No. The loopback IP goes to the Pi-hole, which in turn routes the DNS queries to unbound.
