Unbound isnt working after short powerloss.
I have an pi zero v1.3 with unbound installed.
After a short power blackout pihole is working fine. Only unbound isnt working.
The time is also right.
This is the error code im facing:
ā unbound.service - Unbound DNS server
Active: failed (Result: exit-code) since Wed 2021-12-01 14:12:01 GMT; 6s ago
Docs: man:unbound(8)
Process: 2892 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 2895 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Process: 2899 ExecStart=/usr/sbin/unbound -d $DAEMON_OPTS (code=exited, status=1/FAILURE)
Main PID: 2899 (code=exited, status=1/FAILURE)
Dec 01 14:12:00 raspberrypi systemd[1]: unbound.service: Service RestartSec=100ms expired, scheduling restart.
Dec 01 14:12:00 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 5.
Dec 01 14:12:01 raspberrypi systemd[1]: Stopped Unbound DNS server.
Dec 01 14:12:01 raspberrypi systemd[1]: unbound.service: Start request repeated too quickly.
Dec 01 14:12:01 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Dec 01 14:12:01 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Any ideas?
