This release is a fix for vulnerability CVE-2019-16866 that causes a failure when a specially crafted query is received.
Thanks for posting this.
Any idea how to UPDATE Unbound ? I did the original install with "sudo apt install Unbound" ... but it doesn't look like it ever updates on its own with the usual "sudo apt update". Currently still on 1.9.0-2.
My output of apt-cache policy:
Installed: 1.9.0-2
Candidate: 1.9.0-2
Version table:
*** 1.9.0-2 500
500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
100 /var/lib/dpkg/status
Currently you will probably have to build it.
As it is a security fix I guess a patched version will be available via package managers like apt-get in the next days.
You can follow the Debian Buster package site of Unbound.
Ok cool, I'll give it a week or so to be added to the Raspberry Pi Debian repository, otherwise I'll try to learn how to make/compile it myself. Thanks for the info!
You can install unstable/testing-packages in Debian if you want, just some extra config with apt pinning etc.
