Unable to reach gateway from PiHole
Brand new installation of PiHole, new at this. First time install of PiHole on a Raspberry Pi 3.
Got it up and running, though now I have no external connectivity. DNS is obviously failing. Did some digging and found a default route correctly set on the PiHole to gateway (192.168.2.1), and other devices are able to ping the PiHole, but PiHole is unable to ping the GW (and vice versa). It's directly connected - no idea why directly connected devices on the same network wouldn't be able to ping.
Pihole: 192.168.2.213, Gateway: 192.168.2.1. /24 subnet.
The log can't be uploaded, but I have a text version of it if it helps.
(moderator edit: explicit debug log replaced)
https://tricorder.pi-hole.net/aAttY0kx/
Also, arp failing somehow:
dave@pihole:~ $ arp -a
? (192.168.2.189) at 04:7c:16:04:1d:5a [ether] on eth0
? (192.168.2.1) at on eth0
On the gateway (the router) end, I can see the MAC and DHCP assigned IP of the PiHole fine.
(For your own privacy and security, do not share full, unsanitised debug log output)
This looks like a networking issue, rather than a Pi-hole one.
Your Pi-hole is operational, receiving and processing DNS requests:
*** [ DIAGNOSING ]: contents of /var/log/pihole
   [2025-02-01 00:14:33.185 600M] Imported 5557 queries from the long-term database
   [2025-02-01 00:14:33.186 600M]  -> Total DNS queries: 5557
   [2025-02-01 00:14:33.186 600M]  -> Cached DNS queries: 52
   [2025-02-01 00:14:33.186 600M]  -> Forwarded DNS queries: 4979
   [2025-02-01 00:14:33.186 600M]  -> Blocked DNS queries: 151
   [2025-02-01 00:14:33.186 600M]  -> Unknown DNS queries: 8
   [2025-02-01 00:14:33.186 600M]  -> Unique domains: 117
   [2025-02-01 00:14:33.186 600M]  -> Unique clients: 5
   [2025-02-01 00:14:33.186 600M]  -> Known forward destinations: 1
But your RPi 3 has no public connectivity:
[✓] carpetcleaning-fortworthtx.com is 0.0.0.0 on lo (127.0.0.1)
[✓] carpetcleaning-fortworthtx.com is 0.0.0.0 on eth0 (192.168.2.213)
Also, no DHCP server has been discovered on the link that your RPi is connected to:
   Timeout: 10 seconds
   DHCP packets received on interface eth0: 0
This is unusual, as the RPi obviously has been configured via DHCP at some time, acquiring IP address, search domain and DNS ser
*** [ DIAGNOSING ]: Network interfaces and addresses
       inet 192.168.2.213/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
          valid_lft 258989sec preferred_lft 258989sec
-rw-r--r-- 1 root root 84 Feb  1 00:14 /etc/resolv.conf
   search home
   nameserver 192.168.2.1
   nameserver 8.8.8.8
You should check the cable connection between your router and RPi, maybe try another ethernet port on the router - some routers may set ethernet ports aside for guest network use.
Or they may isolate a device from communicating with others on your network, so check your router for such a feature, and also make sure that your RPi is allowed to access the Internet.
Thank you for the assistance.
I've cleared the lease and added a static reservation, and that seems to have done the trick. Some other (less critical) issues persist, but I'll hack away at those ones. Thanks again!
