Hmmz, after a reboot of my Ubuntu server i got an error:
Jul 25 13:48:22 ip-xxx.xx.xx.xx dnsmasq[23076]: dnsmasq: failed to create listening socket for xxx.xx.xx.xx: Address already in use
Jul 25 13:48:22 ip-xxx.xx.xx.xx dnsmasq[23076]: failed to create listening socket for xxx.xx.xx.xx: Address already in use
Jul 25 13:48:22 ip-xxx.xx.xx.xx dnsmasq[23076]: FAILED to start up
Jul 25 13:48:22 ip-xxx.xx.xx.xx systemd[1]: dnsmasq.service: Control process exited, code=exited status=2
Jul 25 13:48:22 ip-xxx.xx.xx.xx systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
The reason was, dnsmasq.service had started again for some reason...
after running systemctl stop dnsmasq.service and systemctl disable dnsmasq.service and systemctl start pihole-FTL.service eveything works again.
You can, but I think it's a dependency of network manager and it will be installed again on a system (auto) update.
I posted this info here:
Due to the nature of your environment and the presence of Network Manager, after FTLDNS is installed, you need to make sure that Network Manager does NOT enable dnsmasq (at reboot) before FTLDNS. In order to achieve that, you need to edit
/etc/NetworkManager/NetworkManager.conf
And comment out or delete the line that has dns=dnsmasq.
Then you need to restart NetworkManager in order for the new settings (without dnsmasq as resolver) to be applied:
sudo systemctl reload-or-restart NetworkManager
If after reboot, your /admin/ interface is showing Lost Connection To Api and DNS resolution is not working, then that means that FTLDNS is offline.
Once you have done this, you need to find out why dnsmasq is starting.
If you don't use dnsmasq in your own setup, it is safe to uninstall it if you so chose to do so.
sudo apt remove dnsmasq however since it's a dependency of Network Manager, it MIGHT be re-installed if your environment is set-up for auto updates and it will break FTLDNS again.
If you did everything right, dnsmasq shouldn't be a problem once on FTLDNS and the disable method above.
I don't have NetworkManager installed/running. It's a headless server.
Something is starting dnsmasq though... (even though i have disabled the dnsmasq service.)
root:~# systemctl --all|grep -i networkman
● NetworkManager.service not-found inactive dead NetworkManager.service
root:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.5 LTS
Release: 16.04
Codename: xenial
root:/etc/pihole# pihole -v
Pi-hole version is v3.3.1-136-ga7e7680 (Latest: v3.3.1)
AdminLTE version is v3.3-130-g4355bde (Latest: v3.3)
FTL version is vDev-5ecab0a (Latest: v3.0)
PS.
Perhaps it would be useful adding some info about this issue to the beta post, as more people who install the beta will probably run into this problem..?
Version 4.0 implemented a check for port 53 availability (and a couple of checks for what turns on dnsmasq outside Pi-hole). I would really like to know what starts yours ...
