I have as top domains the following:
Where do these come from? Is it because I'm using unbound?
Click on them to see the Query Log showing you who requested these domains.
Forgot to mention: they all come from the local host.
Is there a tool to inspect local requests?
All DNS requests and replies are logged in /var/log/pihole.log, which will show a bit more detail than the query log.
You can use Wireshark or tcpdump on the Pi to see all the packets from localhost.
Feb 16 00:00:38 dnsmasq[31718]: query[A] None from 127.0.0.1
Feb 16 00:00:38 dnsmasq[31718]: config None is NODATA-IPv4
Feb 16 00:00:38 dnsmasq[31718]: query[AAAA] None from 127.0.0.1
Feb 16 00:00:38 dnsmasq[31718]: config None is NODATA-IPv6
Feb 16 00:01:09 dnsmasq[31718]: query[A] None.fritz.box from 127.0.0.1
Feb 16 00:01:09 dnsmasq[31718]: forwarded None.fritz.box to 127.0.0.1
Feb 16 00:01:09 dnsmasq[31718]: query[AAAA] None.fritz.box from 127.0.0.1
Feb 16 00:01:09 dnsmasq[31718]: reply None.fritz.box is NXDOMAIN
I'll have a look with tcpdump tomorrow. Thanks so far!
