Newbie here, using fresh install on TrueNAS, all seems to be working great. As I am now obsessed with watching PiHole do it's thing I notice that my top entry in the table for 'Top Clients (total)' is always my external IP.
Permit All Origins: Can't seem to change that setting.... I think I'm going to have to convert the app to a custom app in order to be able to edit the YAML
The Pi-Hole IP Address: shows as 172.16.3.22 when router shows NAS as 172.16.5.22 and all devices on network are 172.16.5.x.... weird...
Okay so I installed a new instance of PiHole on my NAS but as a custom app, this gave me the power to change the 'Permit All Origins' option, so that's better al least.
PiHole address is still on the wrong subnet so if I choose to 'Allow Only Local Requests' it ignores all traffic. The NAS shows the correct IP address so I'm guessing it's just the container's IP?
My top entry in the table for 'Top Clients (total)' is still always my external IP, where are these requests from? Is it a problem? I don't understand...
Am googling MAVCLAN to understand that suggestion.....
This is normal when using the default bridge network mode.
Docker uses it own network to run container isolated from the local network, but in this case you should use the host IP as Pi-hole address.
The host IP should be used on the router as DNS server, not the internal docker IP.
You can also change your compose file to use host network mode. In this case Pi-hole container will also use the host IP address, but without port forwarding. The container port 80 will be the port 80 on host.
