[“ping google.com” or “git clone (pihole address)” should run normally]
_[Whenever I use a command that points to an non-numerical address I get the error: “Temporary failure in name resolution” or “Could not resolve host: (host)”. This includes ping, git, apt-get. I installed pihole on eth0 (Pi 3b+ running Rasbian lite) then immediately uninstalled because I was supposed to install it on tun0.
The only thing that seems off is the output of “ifconfig -a” which says that eth0’s broadcast is ‘10.255.255.255’ when I believe it should be ‘255.255.255.0’]_
[-bash: pihole: command not found]
