I'm going looking to use pihole as my dhcp server and was testing the import/export functionality (ie. teleporter).
I'm able to backup with "pihole -a -t" - I also checked with tar.gz file and can see that the dnsmasq files are in there.
When doing an import of a freshly installed pihole however, the DHCP files are not imported (ie. directory /etc/dnsmaq.d/). I'm using the Web UI to import, selecting the tar.gz file.
Any ideas if this is suppose to work?
