Hi, I have setup my Synology NAS to act as a reverse proxy. This is also setup to issue certificates which is working fine.
I now want to reverse proxy connections to the pi-hole interface over HTTPS via my Synology NAS.
I have read various forum posts about configuration for NGINX reverse proxy for pi-hole and the standard documentation around having to enable SSL, including the certificate requests / configuration of external.conf e.t.c but none of that seems to fit into what I am trying to achieve.
Basically what I am asking is that does anybody know what I need to do from the pi-hole side in order to enable SSH (what config I need to add) in order to access the pi-hole interface via HTTPS reverse proxied with certificates issued by my NAS
