Suddenly high queries. need help with debug
At 5 o clock my smart home restarted after a backup. Since then, I have a lot of queries:
What is really strange is the top domain ".":
doesn't "." stand for local domain?
Why did I care about this? It seems like pihole was not resolving anything after this high amount of queries anymore. After a reboot it worked again. I think there is one client in the network that is putting a high demand of queries in the network and I would like to identify it. Could you please assist me? I'm totally new with pihole...
No. It is the root domain, essentially the top of the internet.
In your query log, what client is making these requests?
Thank you for clarification. The client is pi.hole :wink:
EDIT:
I found this in the FTL log:
[2022-03-27 14:02:57.333 383M] WARNING in dnsmasq core: Maximum number of concurrent DNS queries reached (max: 150)
[2022-03-27 14:03:14.358 383M] ERR: Port mismatch for 8.8.8.8: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.358 383M] ERR: Port mismatch for 8.8.4.4: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.669 383M] ERR: Port mismatch for 8.8.8.8: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.669 383M] ERR: Port mismatch for 8.8.4.4: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.675 383M] ERR: Port mismatch for 8.8.8.8: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.675 383M] ERR: Port mismatch for 8.8.4.4: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.780 383M] ERR: Port mismatch for 8.8.8.8: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.780 383M] ERR: Port mismatch for 8.8.4.4: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.807 383M] ERR: Port mismatch for 8.8.8.8: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:14.808 383M] ERR: Port mismatch for 8.8.4.4: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:15.086 383M] ERR: Port mismatch for 8.8.8.8: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:15.086 383M] ERR: Port mismatch for 8.8.4.4: we derived 53, dnsmasq told us 48
[2022-03-27 14:03:15.394 383M] ERR: Port mismatch for 8.8.8.8: we derived 53, dnsmasq told us 48
Tools > Generate Debug Log
https://tricorder.pi-hole.net/avxkjOdg/
For the port mismatch issue, here is a related thread.
For the high amount of queries, it is not unusual after an outage (internet upset) for a device to generate a large number of queries.
I note that you have conditional forwarding enabled, which can lead to circular DNS traffic.
    REV_SERVER=true
    REV_SERVER_CIDR=192.168.1.0/24
    REV_SERVER_TARGET=192.168.1.1
    REV_SERVER_DOMAIN=
Please find some example query, forward and reply entries for this domain in your dnsmasq log at /var/log/pihole.log and post them here.
I read that thread but it seems like a bug. So there is nothing I can do, right?
High amount of queries were more than six hours until I restarted the pihole and several devices.
Is the conditional forwarding configured in pihole? Tbh I do not remember to put anything like this in the pi hole settings. Can't find it currently too.
Typically, Pi-hole will not make any queries to the root domain, unless a client has requested it. Please find some example query, forward and reply entries for this domain in your dnsmasq log at /var/log/pihole.log and post them here.
I don't get the content of these phrases. What do you need exactly for further analysis?
The content of "/var/log/pihole.log" is not very interesting , at least for me:
Mar 27 03:10:07 dnsmasq[514]: read /etc/hosts - 6 addresses
Mar 27 03:10:07 dnsmasq[514]: read /etc/pihole/custom.list - 0 addresses
Mar 27 03:10:07 dnsmasq[514]: read /etc/pihole/local.list - 0 addresses
Mar 27 05:44:35 dnsmasq[514]: exiting on receipt of SIGTERM
Mar 27 05:44:40 dnsmasq[29474]: started, version pi-hole-2.87test8 cachesize 10000
Mar 27 05:44:40 dnsmasq[29474]: DNS service limited to local subnets
Mar 27 05:44:40 dnsmasq[29474]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
Mar 27 05:44:40 dnsmasq[29474]: DNSSEC validation enabled
Mar 27 05:44:40 dnsmasq[29474]: configured with trust anchor for <root> keytag 20326
Mar 27 05:44:40 dnsmasq[29474]: using nameserver 8.8.8.8#53
Mar 27 05:44:40 dnsmasq[29474]: using nameserver 8.8.4.4#53
Mar 27 05:44:40 dnsmasq[29474]: using nameserver 192.168.1.1#53 for domain 1.168.192.in-addr.arpa (no DNSSEC)
Mar 27 05:44:40 dnsmasq[29474]: using only locally-known addresses for onion
Mar 27 05:44:40 dnsmasq[29474]: using only locally-known addresses for bind
Mar 27 05:44:40 dnsmasq[29474]: using only locally-known addresses for invalid
Mar 27 05:44:40 dnsmasq[29474]: using only locally-known addresses for localhost
Mar 27 05:44:40 dnsmasq[29474]: using only locally-known addresses for test
Mar 27 05:44:40 dnsmasq[29474]: read /etc/hosts - 6 addresses
Mar 27 05:44:40 dnsmasq[29474]: read /etc/pihole/custom.list - 0 addresses
Mar 27 05:44:40 dnsmasq[29474]: read /etc/pihole/local.list - 0 addresses
Mar 27 05:44:46 dnsmasq[29474]: read /etc/hosts - 6 addresses
Mar 27 05:44:46 dnsmasq[29474]: read /etc/pihole/custom.list - 0 addresses
Mar 27 05:44:46 dnsmasq[29474]: read /etc/pihole/local.list - 0 addresses
Mar 27 05:49:00 dnsmasq[29474]: read /etc/hosts - 6 addresses
Mar 27 05:49:00 dnsmasq[29474]: read /etc/pihole/custom.list - 0 addresses
Mar 27 05:49:00 dnsmasq[29474]: read /etc/pihole/local.list - 0 addresses
Mar 27 05:57:42 dnsmasq[29474]: exiting on receipt of SIGTERM
Mar 27 05:57:56 dnsmasq[354]: started, version pi-hole-2.87test8 cachesize 10000
Mar 27 05:57:56 dnsmasq[354]: DNS service limited to local subnets
Mar 27 05:57:56 dnsmasq[354]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
Mar 27 05:57:56 dnsmasq[354]: DNSSEC validation enabled
Mar 27 05:57:56 dnsmasq[354]: configured with trust anchor for <root> keytag 20326
Mar 27 05:57:56 dnsmasq[354]: using nameserver 8.8.8.8#53
Mar 27 05:57:56 dnsmasq[354]: using nameserver 8.8.4.4#53
Mar 27 05:57:56 dnsmasq[354]: using nameserver 192.168.1.1#53 for domain 1.168.192.in-addr.arpa (no DNSSEC)
Mar 27 05:57:56 dnsmasq[354]: using only locally-known addresses for onion
Mar 27 05:57:56 dnsmasq[354]: using only locally-known addresses for bind
Mar 27 05:57:56 dnsmasq[354]: using only locally-known addresses for invalid
Mar 27 05:57:56 dnsmasq[354]: using only locally-known addresses for localhost
Mar 27 05:57:56 dnsmasq[354]: using only locally-known addresses for test
Mar 27 05:57:56 dnsmasq[354]: read /etc/hosts - 6 addresses
Mar 27 05:57:56 dnsmasq[354]: read /etc/pihole/custom.list - 0 addresses
Mar 27 05:57:56 dnsmasq[354]: read /etc/pihole/local.list - 0 addresses
Mar 27 11:59:15 dnsmasq[383]: started, version pi-hole-2.87test8 cachesize 10000
Mar 27 11:59:15 dnsmasq[383]: DNS service limited to local subnets
Mar 27 11:59:15 dnsmasq[383]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
Mar 27 11:59:15 dnsmasq[383]: DNSSEC validation enabled
Mar 27 11:59:15 dnsmasq[383]: configured with trust anchor for <root> keytag 20326
Mar 27 11:59:15 dnsmasq[383]: using nameserver 8.8.8.8#53
Mar 27 11:59:15 dnsmasq[383]: using nameserver 8.8.4.4#53
Mar 27 11:59:15 dnsmasq[383]: using nameserver 192.168.1.1#53 for domain 1.168.192.in-addr.arpa (no DNSSEC)
Mar 27 11:59:15 dnsmasq[383]: using only locally-known addresses for onion
Mar 27 11:59:15 dnsmasq[383]: using only locally-known addresses for bind
Mar 27 11:59:15 dnsmasq[383]: using only locally-known addresses for invalid
Mar 27 11:59:15 dnsmasq[383]: using only locally-known addresses for localhost
Mar 27 11:59:15 dnsmasq[383]: using only locally-known addresses for test
Mar 27 11:59:15 dnsmasq[383]: read /etc/hosts - 6 addresses
Mar 27 11:59:15 dnsmasq[383]: read /etc/pihole/custom.list - 0 addresses
Mar 27 11:59:15 dnsmasq[383]: read /etc/pihole/local.list - 0 addresses
Mar 27 13:16:09 dnsmasq[383]: Maximum number of concurrent DNS queries reached (max: 150)
Mar 27 13:16:15 dnsmasq[383]: Maximum number of concurrent DNS queries reached (max: 150)
Mar 27 13:16:24 dnsmasq[383]: Maximum number of concurrent DNS queries reached (max: 150)
Mar 27 13:16:30 dnsmasq[383]: Maximum number of concurrent DNS queries reached (max: 150)
Mar 27 19:12:42 dnsmasq[383]: Maximum number of concurrent DNS queries reached (max: 150)
Mar 27 19:13:59 dnsmasq[383]: Maximum number of concurrent DNS queries reached (max: 150)
Mar 27 19:14:10 dnsmasq[383]: Maximum number of concurrent DNS queries reached (max: 150)
Mar 27 19:14:16 dnsmasq[383]: Maximum number of concurrent DNS queries reached (max: 150)
Additionally I don't get the connection to pi.hole client queries because they won't be logged to the pihole.log, right?
Sorry, I need additional support with this...
You have DNSSEC enabled. Pi-hole needs to start from the root zone in order to validate DNSSEC chain of trust.
Yes. The output I posted is from your debug log.
