Chadi
December 9, 2019, 2:26pm
1
Blocking ads, logging queries
Stopped working altogether. Rebooted system, rebooted VPS, flushed DNS cache.
[✓] Your debug token is: https://tricorder.pi-hole.net/3hv8ogg2qj
jfb
December 9, 2019, 2:39pm
2
When you post a debug token, we only need the token, not the entire log. This keeps your debug log private. I edited your post to include just the token.
jfb
December 9, 2019, 2:46pm
3
Your debug log shows that Pi-Hole is working normally, but has received no DNS queries.
Your Pi-Hole is open to the world (you are running an open resolver). You should close this immediately.
Chadi
December 9, 2019, 2:47pm
4
Ok
I just realized that it works on LTE but not on the Wi-Fi at the hotel where I am. I even tried to manually set the Wi-Fi DNS to my VPS IP address but it did not solve it. Odd.
jfb
December 9, 2019, 2:48pm
5
As I noted, you should immediately close this open resolver. It will be discovered and put to no good use very quickly.
Chadi
December 9, 2019, 2:54pm
6
How do I close the resolver?
jfb
December 9, 2019, 3:01pm
7
Set up a VPN to your VPS or set up strong firewall rules so that only your IP can access it. As is, you have both port 53 and port 80 on the VPS open to the world, and anybody can use your Pi-Hole.
Chadi
December 9, 2019, 3:21pm
8
In other words, I should basically disable port 53 and 80 (disable web gui)?
Chadi
9
In the meantime however, I would like to know why it doesn't work on the hotel wifi but works fine on LTE.
drewski
December 9, 2019, 3:23pm
10
Because you don't have control of port 53 on the hotel WiFi.
Chadi
December 9, 2019, 3:30pm
11
Ok I guess I understand but I haven't modified anything at my home router either and it works there. Strange.
drewski
December 9, 2019, 4:58pm
12
It's because they are specifically stopping you. They did go into the router and change things. Hope you understand this correctly.
system
Closed
December 30, 2019, 4:58pm
13
