Stoping IP Loggers to probing me
Hello to All
I as wondering if is possible to block Grabify and other likes it using pi-hole.
There are other IP-loggers I just use this one as example...or if u can indicate a list that all the IP-loggers are already mentioned is also be useful.
Thanks guys!
don't know if this helps. according to this page, there are several (4 mentioned on this page) IP address grabbers.
I assume, adding these wildcard entries (blacklist), will stop them.
