Here it is with a "-x" after the bash command.
[e[1;32m✓e[0m] Root user check
e[1;32m.;;,.
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
e[1;31m.. ','.
..'''.e[0m
[i] Existing PHP installation detected : PHP version 5.5.9-1ubuntu4.25
[e[1;32m✓e[0m] Disk space check
[i] Update local cache of available packages...
e[K [e[1;32m✓e[0m] Update local cache of available packages
[i] Checking apt-get for upgraded packages...
e[K [e[1;32m✓e[0m] Checking apt-get for upgraded packages... 23 updates available
[i] e[1;32mIt is recommended to update your OS after installing the Pi-hole! e[0m
[i] Checking for apt-utils...
e[K [e[1;32m✓e[0m] Checking for apt-utils
[i] Checking for dialog...
e[K [e[1;32m✓e[0m] Checking for dialog
[i] Checking for debconf...
e[K [e[1;32m✓e[0m] Checking for debconf
[i] Checking for dhcpcd5...
e[K [e[1;32m✓e[0m] Checking for dhcpcd5
[i] Checking for git...
e[K [e[1;32m✓e[0m] Checking for git
[i] Checking for iproute2...
e[K [e[1;32m✓e[0m] Checking for iproute2
[i] Checking for whiptail...
e[K [e[1;32m✓e[0m] Checking for whiptail
e[?1049he[1;46re[4le[?25le(Be[me[37me[40me[1;46re[He[2Je[1;1He[1me[37me[45m e[2;1H e[3;1H e[4;1H e[5;1H e[6;1H e[7;1H e[8;1H e[9;1H e[10;1H e[11;1H e[12;1H e[13;1H e[14;1H e[15;1H e[16;1H e[17;1H e[18;1H e[19;1H e[20;1H e[21;1H e[22;1H e[23;1H e[24;1H e[25;1H e[26;1H e[27;1H e[28;1H e[29;1H e[30;1H e[31;1H e[32;1H e[33;1H e[34;1H e[35;1H e[36;1H e[37;1H e[38;1H e[39;1H e[40;1H e[41;1H e[42;1H e[43;1H e[44;1H e[45;1H e[46;1H e[46;146H e[4h e[4le[1;1He(Be[me[37me[45mWelcomee[14;39He[30me[47m┌──────────────────┤ e[31mPi-hole automated installere[30m ├───────────────────┐e[15;39H│ │e[1me[37me[40m e[16;39He(Be[me[30me[47m│ │e[1me[37me[40m e[17;39He(Be[me[30me[47m│ │e[1me[37me[40m e[18;39He(Be[me[30me[47m│ This installer will transform your device into a network-wide ad │e[1me[37me[40m e[19;39He(Be[me[30me[47m│ blocker! │e[1me[37me[40m e[20;39He(Be[me[30me[47m│ │e[1me[37me[40m e[21;39He(Be[me[30me[47m│ │e[1me[37me[40m e[22;39He(Be[me[30me[47m│ │e[1me[37me[40m e[23;39He(Be[me[30me[47m│ │e[1me[37me[40m e[24;39He(Be[me[30me[47m│ │e[1me[37me[40m e[25;39He(Be[me[30me[47m│ │e[1me[37me[40m e[26;39He(Be[me[30me[47m│ │e[1me[37me[40m e[27;39He(Be[me[30me[47m│ │e[1me[37me[40m e[28;39He(Be[me[30me[47m│ │e[1me[37me[40m e[29;39He(Be[me[30me[47m│ │e[1me[37me[40m e[30;39He(Be[me[30me[47m│ │e[1me[37me[40m e[31;39He(Be[me[30me[47m│ e[37me[41m<Ok>e[30me[47m │e[1me[37me[40m e[32;39He(Be[me[30me[47m│ │e[1me[37me[40m e[33;39He(Be[me[30me[47m└────────────────────────────────────────────────────────────────────┘e[1me[37me[40m e[34;40H e[31;72He[?12le[?25he[46;1He(Be[me[37me[40me(Be[me[39;49m
e[K
e[?1049le[?1049he[1;46re[4le[?25le(Be[me[37me[40me[1;46re[He[2Je[1;1He[1me[37me[45m e[2;1H e[3;1H e[4;1H e[5;1H e[6;1H e[7;1H e[8;1H e[9;1H e[10;1H e[11;1H e[12;1H e[13;1H e[14;1H e[15;1H e[16;1H e[17;1H e[18;1H e[19;1H e[20;1H e[21;1H e[22;1H e[23;1H e[24;1H e[25;1H e[26;1H e[27;1H e[28;1H e[29;1H e[30;1H e[31;1H e[32;1H e[33;1H e[34;1H e[35;1H e[36;1H e[37;1H e[38;1H e[39;1H e[40;1H e[41;1H e[42;1H e[43;1H e[44;1H e[45;1H e[46;1H e[46;146H e[4h e[4le[1;1He(Be[me[37me[45mPleae[14;39He[30me[47m┌──────────────────────┤ e[31mFree and open sourcee[30m ├──────────────────────┐e[15;39H│ │e[1me[37me[40m e[16;39He(Be[me[30me[47m│ │e[1me[37me[40m e[17;39He(Be[me[30me[47m│ │e[1me[37me[40m e[18;39He(Be[me[30me[47m│ The Pi-hole is free, but powered by your donations: │e[1me[37me[40m e[19;39He(Be[me[30me[47m│ http://pi-hole.net/donate │e[1me[37me[40m e[20;39He(Be[me[30me[47m│ │e[1me[37me[40m e[21;39He(Be[me[30me[47m│ │e[1me[37me[40m e[22;39He(Be[me[30me[47m│ │e[1me[37me[40m e[23;39He(Be[me[30me[47m│ │e[1me[37me[40m e[24;39He(Be[me[30me[47m│ │e[1me[37me[40m e[25;39He(Be[me[30me[47m│ │e[1me[37me[40m e[26;39He(Be[me[30me[47m│ │e[1me[37me[40m e[27;39He(Be[me[30me[47m│ │e[1me[37me[40m e[28;39He(Be[me[30me[47m│ │e[1me[37me[40m e[29;39He(Be[me[30me[47m│ │e[1me[37me[40m e[30;39He(Be[me[30me[47m│ │e[1me[37me[40m e[31;39He(Be[me[30me[47m│ e[37me[41m<Ok>e[30me[47m │e[1me[37me[40m e[32;39He(Be[me[30me[47m│ │e[1me[37me[40m e[33;39He(Be[me[30me[47m└────────────────────────────────────────────────────────────────────┘e[1me[37me[40m e[34;40H e[31;72He[?12le[?25he[46;1He(Be[me[37me[40me(Be[me[39;49m
e[K
e[?1049l+ set -e
+ installLogLoc=/etc/pihole/install.log
+ setupVars=/etc/pihole/setupVars.conf
+ lighttpdConfig=/etc/lighttpd/lighttpd.conf
+ coltable=/opt/pihole/COL_TABLE
+ webInterfaceGitUrl=https://github.com/pi-hole/AdminLTE.git
+ webInterfaceDir=/var/www/html/admin
+ piholeGitUrl=https://github.com/pi-hole/pi-hole.git
+ PI_HOLE_LOCAL_REPO=/etc/.pihole
+ PI_HOLE_FILES=(chronometer list piholeDebug piholeLogFlush setupLCD update version gravity uninstall webpage)
+ PI_HOLE_INSTALL_DIR=/opt/pihole
+ PI_HOLE_CONFIG_DIR=/etc/pihole
+ useUpdateVars=false
+ adlistFile=/etc/pihole/adlists.list
+ regexFile=/etc/pihole/regex.list
+ IPV4_ADDRESS=
+ IPV6_ADDRESS=
+ QUERY_LOGGING=true
+ INSTALL_WEB_INTERFACE=true
+ '[' -z root ']'
++ stty size
++ echo 24 80
+ screen_size='24 80'
++ echo '24 80'
++ awk '{print $1}'
+ rows=24
++ echo '24 80'
++ awk '{print $2}'
+ columns=80
+ r=12
+ c=40
+ r=20
+ c=70
+ skipSpaceCheck=false
+ reconfigure=false
+ runUnattended=false
+ INSTALL_WEB_SERVER=true
+ [[ -f /opt/pihole/COL_TABLE ]]
+ COL_NC='\e[0m'
+ COL_LIGHT_GREEN='\e[1;32m'
+ COL_LIGHT_RED='\e[1;31m'
+ TICK='[\e[1;32m✓\e[0m]'
+ CROSS='[\e[1;31m✗\e[0m]'
+ INFO='[i]'
+ DONE='\e[1;32m done!\e[0m'
+ OVER='\r\033[K'
+ counter=0
+ [[ '' != true ]]
+ main
+ local 'str=Root user check'
+ echo ''
+ [[ 0 -eq 0 ]]
+ echo -e ' [\e[1;32m✓\e[0m] Root user check'
+ show_ascii_berry
+ echo -e '
\e[1;32m.;;,.
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'\''ccll:;ll .oooodc
.;cll.;;looo:.
\e[1;31m.. '\'','\''.
..'\'''\'''\''.\e[0m
e[1;32m.;;,.
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
e[1;31m.. ','.
..'''.e[0m
+ make_temporary_log
++ mktemp /tmp/pihole_temp.XXXXXX
+ TEMPLOG=/tmp/pihole_temp.yheYae
+ exec
+ rm /tmp/pihole_temp.yheYae
+ distro_check
+ command -v apt-get
+ PKG_MANAGER=apt-get
+ UPDATE_PKG_CACHE='apt-get update'
+ PKG_INSTALL=(${PKG_MANAGER} --yes --no-install-recommends install)
+ PKG_COUNT='apt-get -s -o Debug::NoLocking=true upgrade | grep -c ^Inst || true'
+ apt-get install --dry-run iproute2
+ iproute_pkg=iproute2
+ command -v php
++ php -v
++ grep -Po '(?<=PHP )[^ ]+'
++ head -n1
+ phpInsVersion=5.5.9-1ubuntu4.25
+ echo -e ' [i] Existing PHP installation detected : PHP version 5.5.9-1ubuntu4.25'
++ echo 5.5.9-1ubuntu4.25
++ cut -d. -f1
+ phpInsMajor=5
++ cut -d. -f2
+ phpInsMinor=5
++ echo '5.5 < 7.0'
++ bc
+ '[' 1 == 0 ']'
+ [[ '' != true ]]
+ apt-get install --dry-run php
+ phpVer=php5
+ apt-get install --dry-run php5-sqlite3
+ phpSqlite=sqlite
+ INSTALLER_DEPS=(apt-utils dialog debconf dhcpcd5 git ${iproute_pkg} whiptail)
+ PIHOLE_DEPS=(bc cron curl dnsutils iputils-ping lsof netcat psmisc sudo unzip wget idn2 sqlite3 libcap2-bin dns-root-data resolvconf)
+ PIHOLE_WEB_DEPS=(lighttpd ${phpVer}-common ${phpVer}-cgi ${phpVer}-${phpSqlite})
+ LIGHTTPD_USER=www-data
+ LIGHTTPD_GROUP=www-data
+ LIGHTTPD_CFG=lighttpd.conf.debian
+ [[ -f /etc/pihole/setupVars.conf ]]
+ [[ false == true ]]
+ verifyFreeDiskSpace
+ local 'str=Disk space check'
+ local required_free_kilobytes=51200
+ local existing_free_kilobytes
++ df -Pk
++ grep -m1 '\/$'
++ awk '{print $4}'
+ existing_free_kilobytes=24170972
+ [[ 24170972 =~ ^([0-9])+$ ]]
+ [[ 24170972 -lt 51200 ]]
+ echo -e ' [\e[1;32m✓\e[0m] Disk space check'
+ update_package_cache
+ local 'str=Update local cache of available packages'
+ echo ''
+ echo -ne ' [i] Update local cache of available packages...'
[i] Update local cache of available packages...+ eval 'apt-get update'
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Update local cache of available packages'
+ notify_package_updates_available
+ local 'str=Checking apt-get for upgraded packages'
+ echo -ne '\n [i] Checking apt-get for upgraded packages...'
[i] Checking apt-get for upgraded packages...++ eval 'apt-get -s -o Debug::NoLocking=true upgrade | grep -c ^Inst || true'
+++ apt-get -s -o Debug::NoLocking=true upgrade
+++ grep -c '^Inst'
+ updatesToInstall=23
++ uname -r
+ [[ -d /lib/modules/3.13.0-32-generic ]]
+ [[ 23 -eq 0 ]]
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Checking apt-get for upgraded packages... 23 updates available'
+ echo -e ' [i] \e[1;32mIt is recommended to update your OS after installing the Pi-hole! \e[0m'
+ echo ''
+ install_dependent_packages 'INSTALLER_DEPS[@]'
+ counter=1
+ [[ 1 == 1 ]]
+ echo -e ' [i] Installer Dependency checks...'
+ argArray1=("${!1}")
+ declare -a argArray1
+ declare -a installArray
+ command -v debconf-apt-progress
+ for i in '"${argArray1[@]}"'
+ echo -ne ' [i] Checking for apt-utils...'
[i] Checking for apt-utils...+ grep 'ok installed'
+ dpkg-query -W '-f=${Status}' apt-utils
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Checking for apt-utils'
+ echo -ne ' [i] Checking for dialog...'
[i] Checking for dialog...+ dpkg-query -W '-f=${Status}' dialog
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Checking for dialog'
+ echo -ne ' [i] Checking for debconf...'
[i] Checking for debconf...+ dpkg-query -W '-f=${Status}' debconf
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Checking for debconf'
+ echo -ne ' [i] Checking for dhcpcd5...'
[i] Checking for dhcpcd5...+ dpkg-query -W '-f=${Status}' dhcpcd5
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Checking for dhcpcd5'
+ echo -ne ' [i] Checking for git...'
[i] Checking for git...+ dpkg-query -W '-f=${Status}' git
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Checking for git'
+ echo -ne ' [i] Checking for iproute2...'
[i] Checking for iproute2...+ dpkg-query -W '-f=${Status}' iproute2
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Checking for iproute2'
+ echo -ne ' [i] Checking for whiptail...'
[i] Checking for whiptail...+ grep 'ok installed'
+ dpkg-query -W '-f=${Status}' whiptail
+ echo -e '\r\033[K [\e[1;32m✓\e[0m] Checking for whiptail'
+ [[ 0 -gt 0 ]]
+ echo ''
+ return 0
+ checkSelinux
+ command -v getenforce
+ [[ false == false ]]
+ welcomeDialogs
+ whiptail --msgbox --backtitle Welcome --title 'Pi-hole automated installer' '\n\nThis installer will transform your device into a network-wide ad blocker!' 20 70
e[?1049he[1;24re[4le[?25le(Be[me[37me[40me[1;24re[He[2Je[1;1He[1me[37me[45m e[2;1H e[3;1H e[4;1H e[5;1H e[6;1H e[7;1H e[8;1H e[9;1H e[10;1H e[11;1H e[12;1H e[13;1H e[14;1H e[15;1H e[16;1H e[17;1H e[18;1H e[19;1H e[20;1H e[21;1H e[22;1H e[23;1H e[24;1H e[24;79H e[4h e[4le[1;1He(Be[me[37me[45mWelcomee[3;6He[30me[47m┌──────────────────┤ e[31mPi-hole automated installere[30m ├───────────────────┐e[4;6H│ │e[1me[37me[40m e[5;6He(Be[me[30me[47m│ │e[1me[37me[40m e[6;6He(Be[me[30me[47m│ │e[1me[37me[40m e[7;6He(Be[me[30me[47m│ This installer will transform your device into a network-wide ad │e[1me[37me[40m e[8;6He(Be[me[30me[47m│ blocker! │e[1me[37me[40m e[9;6He(Be[me[30me[47m│ │e[1me[37me[40m e[10;6He(Be[me[30me[47m│ │e[1me[37me[40m e[11;6He(Be[me[30me[47m│ │e[1me[37me[40m e[12;6He(Be[me[30me[47m│ │e[1me[37me[40m e[13;6He(Be[me[30me[47m│ │e[1me[37me[40m e[14;6He(Be[me[30me[47m│ │e[1me[37me[40m e[15;6He(Be[me[30me[47m│ │e[1me[37me[40m e[16;6He(Be[me[30me[47m│ │e[1me[37me[40m e[17;6He(Be[me[30me[47m│ │e[1me[37me[40m e[18;6He(Be[me[30me[47m│ │e[1me[37me[40m e[19;6He(Be[me[30me[47m│ │e[1me[37me[40m e[20;6He(Be[me[30me[47m│ e[37me[41m<Ok>e[30me[47m │e[1me[37me[40m e[21;6He(Be[me[30me[47m│ │e[1me[37me[40m e[22;6He(Be[me[30me[47m└────────────────────────────────────────────────────────────────────┘e[1me[37me[40m e[23;7H e[20;39He[?12le[?25h
