SSL received a record that exceeded the maximum permissible length
Logging into pi.hole should ask for password and display webui
  • Debian GNU/Linux bookworm 12.15 aarch64
  • Raspberry Pi 3 Model B Rev 1.2
  • Core
    Version is v6.4.3 (Latest: v6.4.3)
    Branch is master
    Hash is f47b8ede (Latest: f47b8ede)
    Web
    Version is v6.6 (Latest: v6.6)
    Branch is master
    Hash is b2a40784 (Latest: b2a40784)
    FTL
    Version is vDev-40d76e9 (Latest: N/A)
    Branch is development
    Hash is 40d76e91 (Latest: 40d76e91)Docker compose file or Docker run command
Rather than asking for password, I get:
Secure Connection Failed
An error occurred during a connection to pi.hole. SSL received a record that exceeded the maximum permissible length.
token is: https://tricorder.pi-hole.net/WIUnJsBA/
Actions taken:
Error started after doing: pihole -up
Rebooted system and changed browsers, same error
You are using FTL development.
This version has some changes related to SSL and I think it is probably causing some incompatibility, specially if used with Core and Web master branches.
Try to use the current FTL release if this command:
sudo pihole checkout ftl master
Does this fix the issue?
