Spotify Album/Song covers don't load
A few observations from your debug log.
You have multiple IP's assigned to the same interface on the Pi. This can cause problems if you did not set this up intentionally.
   10.0.0.123/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   10.0.0.3/24 matches the IP found in /etc/pihole/setupVars.conf
You have multiple gateways assigned.
[i] Default IPv4 gateway: 10.0.0.2
10.0.0.2
10.0.3.2
Here is another indication that your blocklists contain some garbage:
[✗] Failed to resolve r9---sn--gqn-vu2l.googlevideo.com via localhost (127.0.0.1)
[✗] Failed to resolve r9---sn--gqn-vu2l.googlevideo.com via Pi-hole (10.0.0.3)
[✓] doubleclick.com is 172.217.16.110 via a remote, public DNS server (8.8.8.8)
dig +short r9---sn--gqn-vu2l.googlevideo.com
dig: 'r9---sn--gqn-vu2l.googlevideo.com' is not a legal IDN name (string contains forbidden two hyphens pattern), use +noidnin
I don't know why I have 2 IP address assigned. I have set 10.0.0.3 as static. I don't know why the other one came in.
I have removed that 3 blocklists which contains invalid characters.
Run this command which will show you the non-commented lines in /etc/dhcpcd.conf
sudo grep -v '#\|^$' /etc/dhcpcd.conf
If there are duplicate entries for the same interface, fix that.
I think you are missing the point. The problem is not with those few blocklists that you aren't loading, the problem is with the blocklists that are not proper for Pi-hole that you are trying to force into your gravity list.
I don't have anything multiple IPs:
hostname
clientid
persistent
option rapid_commit
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
option interface_mtu
require dhcp_server_identifier
slaac private
interface eth0
static ip_address=10.0.0.3/24
static routers=10.0.0.2
I got your point, removed most of the blocklists which seemed incorrect.
