Hi All,
recently spiegel.de have started showing popups requesting to disable ABP (I'm actually using pi-hole).
Has anybody found a solution to this issue yet ?
Hi All,
Hi, I can second that Spiegel.de has started to use Adblockerblocker which is some kind of annoying. Would be beneficial to find a workaround or, if prefered, to be able to whitelist Spiegel.de.
Thanks for considering the possibilities.
I've just run into the same problem today.
I'd also be willing to whitelist spiegel.de as a workaround, but I don't know which domains to whitelist. Any ideas?
I'm also interested in a solution to this problem.
Thanks, bernd123,
seems to work! Good stuff!
Yep, works well so far. Let's hope this doesn"t turn into a cat & mouse game... Thanks a lot Bernd123/
Not that important: but now the same story on bild.de. I don't care too much but as mentioned earlier I'm also afraid that could lead into cat & mouse game.
Update 01/03/2018:
Again pop-ups on spiegel.de despite whitelisting "imagesrv.adition.com". The cat is back....
Oh, my bad.
Blacklist just "spiegel-de.spiegel.de", not "http://spiegel-de.spiegel.de"
Sorry.
Thanks a bunch! Works perfectly after browser cache cleared....
You made my day!
Cheers, belierzz
Hi
just tried it and I still get the pop-up from Spiegel. Any new view on this?
