sudo rgrep -v '^ *#\|^$' /etc/unbound/unbound.conf*
sudo unbound-checkconf
sudo journalctl --full --no-pager --lines 30 -u unbound.service
EDIT: Sorry I editted that last one!
pi@raspberrypi:/etc $ sudo rgrep -v '^ *#\|^$' /etc/unbound/unbound.conf*
/etc/unbound/unbound.conf.d/pi-hole.conf: verbosity: 0
/etc/unbound/unbound.conf.d/pi-hole.conf: interface: 127.0.0.1
/etc/unbound/unbound.conf.d/pi-hole.conf: port: 5335
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip4: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-udp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-tcp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: prefer-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-glue: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-dnssec-stripped: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: use-caps-for-id: no
/etc/unbound/unbound.conf.d/pi-hole.conf: edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/pi-hole.conf: prefetch: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: num-threads: 1
/etc/unbound/unbound.conf.d/pi-hole.conf: so-rcvbuf: 1m
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 192.168.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 169.254.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 172.16.0.0/12
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 10.0.0.0/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fd00::/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fe80::/10
pi@raspberrypi:/etc $ sudo unbound-checkconf
[1700248734] unbound-checkconf[13442:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
This is granted, because the pihole doco has this config in /etc/unbound/unbound.conf.d/pi-hole.conf
pi@raspberrypi:/etc $ sudo journalctl --full --no-pager --lines 30 -u unbound.service
-- Logs begin at Fri 2023-11-17 20:11:21 IST, end at Fri 2023-11-17 21:19:57 IST. --
Nov 17 21:18:04 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 17 21:18:04 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 17 21:18:04 raspberrypi package-helper[13425]: [1700248684] unbound-checkconf[13427:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Nov 17 21:18:04 raspberrypi package-helper[13428]: [1700248684] unbound-checkconf[13430:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Nov 17 21:18:04 raspberrypi unbound[13431]: [1700248684] unbound[13431:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Nov 17 21:18:04 raspberrypi unbound[13431]: [1700248684] unbound[13431:0] warning: Continuing with default config settings
Nov 17 21:18:04 raspberrypi unbound[13431]: [1700248684] unbound[13431:0] error: can't bind socket: Address already in use for ::1 port 53
Nov 17 21:18:04 raspberrypi unbound[13431]: [1700248684] unbound[13431:0] fatal error: could not open ports
Nov 17 21:18:04 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 17 21:18:04 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 17 21:18:04 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Nov 17 21:18:04 raspberrypi systemd[1]: unbound.service: Service RestartSec=100ms expired, scheduling restart.
Nov 17 21:18:04 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 4.
Nov 17 21:18:04 raspberrypi package-helper[13432]: [1700248684] unbound-checkconf[13434:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Nov 17 21:18:04 raspberrypi package-helper[13435]: [1700248684] unbound-checkconf[13437:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Nov 17 21:18:04 raspberrypi unbound[13438]: [1700248684] unbound[13438:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Nov 17 21:18:04 raspberrypi unbound[13438]: [1700248684] unbound[13438:0] warning: Continuing with default config settings
Nov 17 21:18:04 raspberrypi unbound[13438]: [1700248684] unbound[13438:0] error: can't bind socket: Address already in use for ::1 port 53
Nov 17 21:18:04 raspberrypi unbound[13438]: [1700248684] unbound[13438:0] fatal error: could not open ports
Nov 17 21:18:05 raspberrypi systemd[1]: unbound.service: Service RestartSec=100ms expired, scheduling restart.
Nov 17 21:18:05 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 5.
Nov 17 21:18:05 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 17 21:18:05 raspberrypi systemd[1]: unbound.service: Start request repeated too quickly.
Nov 17 21:18:05 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 17 21:18:05 raspberrypi systemd[1]: Failed to start Unbound DNS server.
I used to have unbound-13.0 that I compiled myself based on a guide I had.
Is there a way to totally nuke anything that is unbound related? Maybe somethings needs to be reversed?
You're missing below file with a very important include directive:
pi@ph5a:~ $ sudo rgrep -v '^ *#\|^$' /etc/unbound/unbound.conf*
/etc/unbound/unbound.conf:include: "/etc/unbound/unbound.conf.d/*.conf"
It's included in the unbound package:
pi@ph5a:~ $ dpkg -S unbound.conf
unbound: /etc/unbound/unbound.conf
Can try reinstall it with below:
sudo apt -o Dpkg::Options::="--force-confmiss" install --reinstall unbound
Whats your OS release?
hostnamectl | grep Operating
I believe you're missing more.
/etc/unbound/unbound.conf.d/qname-minimisation.conf:server:
/etc/unbound/unbound.conf.d/qname-minimisation.conf: qname-minimisation: yes
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf: auto-trust-anchor-file: "/var/lib/unbound/root.key"
pi@raspberrypi:/etc $ sudo apt -o Dpkg::Options::="--force-confmiss" install --reinstall unbound
Reading package lists... Done
Building dependency tree
Suggested packages:
apparmor
unbound
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 674 kB of archives.
After this operation, 3,646 kB of additional disk space will be used.
Get:1 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf unbound armhf 1.9.0-2+deb10u3 [674 kB]
Fetched 674 kB in 2s (370 kB/s)
Selecting previously unselected package unbound.
(Reading database ... 157368 files and directories currently installed.)
Preparing to unpack .../unbound_1.9.0-2+deb10u3_armhf.deb ...
Unpacking unbound (1.9.0-2+deb10u3) ...
Setting up unbound (1.9.0-2+deb10u3) ...
Job for unbound.service failed because the control process exited with error code.
See "systemctl status unbound.service" and "journalctl -xe" for details.
invoke-rc.d: initscript unbound, action "restart" failed.
Active: activating (auto-restart) (Result: exit-code) since Fri 2023-11-17 22:08:48 IST; 28ms ago
Docs: man:unbound(8)
Process: 14242 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 14245 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Process: 14248 ExecStart=/usr/sbin/unbound -d $DAEMON_OPTS (code=exited, status=1/FAILURE)
Main PID: 14248 (code=exited, status=1/FAILURE)
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for systemd (241-7~deb10u9+rpi1) ...
Operating System: Raspbian GNU/Linux 10 (buster)
Below would help if still not working?
Oh I also have a buster node:
pi@ph5a:~ $ hostnamectl | grep Operating
Looks like this:
pi@ph5a:~ $ dpkg -L unbound
/var/lib/unbound/root.key: No such file or directory
[1700468836] unbound-checkconf[5564:0] fatal error: auto-trust-anchor-file: "/var/lib/unbound/root.key" does not exist
-- Logs begin at Fri 2023-11-17 20:11:21 IST, end at Mon 2023-11-20 10:27:25 IST. --
Nov 17 22:08:50 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 17 22:08:50 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 17 22:08:50 raspberrypi unbound[14317]: [14317:0] error: unable to open /var/lib/unbound/root.key for reading: No such file or directory
Nov 17 22:08:50 raspberrypi unbound[14317]: [14317:0] error: error reading auto-trust-anchor-file: /var/lib/unbound/root.key
Nov 17 22:08:50 raspberrypi unbound[14317]: [14317:0] error: validator: error in trustanchors config
Nov 17 22:08:50 raspberrypi unbound[14317]: [14317:0] error: validator: could not apply configuration settings.
Nov 17 22:08:50 raspberrypi unbound[14317]: [14317:0] error: module init for module validator failed
Nov 17 22:08:50 raspberrypi unbound[14317]: [14317:0] fatal error: failed to setup modules
Nov 17 22:08:50 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 17 22:08:50 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 17 22:08:50 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Nov 17 22:08:50 raspberrypi systemd[1]: unbound.service: Service RestartSec=100ms expired, scheduling restart.
Nov 17 22:08:50 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 8.
Nov 17 22:08:50 raspberrypi unbound[14328]: [14328:0] error: unable to open /var/lib/unbound/root.key for reading: No such file or directory
Nov 17 22:08:50 raspberrypi unbound[14328]: [14328:0] error: error reading auto-trust-anchor-file: /var/lib/unbound/root.key
Nov 17 22:08:50 raspberrypi unbound[14328]: [14328:0] error: validator: error in trustanchors config
Nov 17 22:08:50 raspberrypi unbound[14328]: [14328:0] error: validator: could not apply configuration settings.
Nov 17 22:08:50 raspberrypi unbound[14328]: [14328:0] error: module init for module validator failed
Nov 17 22:08:50 raspberrypi unbound[14328]: [14328:0] fatal error: failed to setup modules
Nov 17 22:08:50 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 9.
Nov 17 22:08:50 raspberrypi systemd[1]: unbound.service: Start request repeated too quickly.
/etc
/etc/apparmor.d
/etc/apparmor.d/usr.sbin.unbound
/etc/default
/etc/init.d
/etc/init.d/unbound
/etc/insserv.conf.d
/etc/insserv.conf.d/unbound
/etc/resolvconf
/etc/resolvconf/update.d
/etc/resolvconf/update.d/unbound
/etc/unbound
/lib
/lib/systemd
/lib/systemd/system
/lib/systemd/system/unbound-resolvconf.service
/usr
/usr/lib
/usr/lib/resolvconf
/usr/lib/resolvconf/dpkg-event.d
/usr/lib/resolvconf/dpkg-event.d/unbound
/usr/lib/unbound
/usr/sbin
/usr/sbin/unbound
/usr/sbin/unbound-checkconf
/usr/sbin/unbound-control
/usr/sbin/unbound-control-setup
/usr/share
/usr/share/doc
/usr/share/doc/unbound
/usr/share/doc/unbound/CREDITS
/usr/share/doc/unbound/FEATURES
/usr/share/doc/unbound/NEWS.Debian.gz
/usr/share/doc/unbound/README.DNS64
/usr/share/doc/unbound/README.gz
/usr/share/doc/unbound/TODO.gz
/usr/share/doc/unbound/changelog.Debian.gz
/usr/share/doc/unbound/changelog.gz
/usr/share/doc/unbound/contrib
/usr/share/doc/unbound/contrib/update-anchor.sh.gz
/usr/share/doc/unbound/copyright
/usr/share/doc/unbound/examples
/usr/share/doc/unbound/examples/unbound.conf
/usr/share/man
/usr/share/man/man5
/usr/share/man/man5/unbound.conf.5.gz
/usr/share/man/man8
/usr/share/man/man8/unbound-checkconf.8.gz
/usr/share/man/man8/unbound-control.8.gz
/usr/share/man/man8/unbound.8.gz
/usr/share/munin
/usr/share/munin/plugins
/usr/share/munin/plugins/unbound_munin_
/var
/var/lib
/var/lib/unbound
I removed Unbound and deleted the /etc/unbound folder.
Then I reinstalled it using the Pihole documentation, and you can see the results. Something there is not working as intended.
pi@raspberrypi:~ $ journalctl -u unbound.service
-- Logs begin at Fri 2023-11-17 20:11:21 IST, end at Mon 2023-11-20 10:48:33 IST. --
Nov 17 20:11:27 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 17 20:11:28 raspberrypi package-helper[477]: [1700244688] unbound-checkconf[481:0] error: Could not open /etc/unbounNov 17 20:11:28 raspberrypi package-helper[520]: [1700244688] unbound-checkconf[524:0] error: Could not open /etc/unbounNov 17 20:11:28 raspberrypi unbound[527]: [1700244688] unbound[527:0] error: Could not open /etc/unbound/unbound.conf: NNov 17 20:11:28 raspberrypi unbound[527]: [1700244688] unbound[527:0] warning: Continuing with default config settings
Nov 17 20:11:28 raspberrypi unbound[527]: [527:0] notice: init module 0: subnet
Nov 17 20:11:28 raspberrypi unbound[527]: [527:0] notice: init module 1: validator
Nov 17 20:11:28 raspberrypi unbound[527]: [527:0] notice: init module 2: iterator
Nov 17 20:11:28 raspberrypi unbound[527]: [527:0] info: start of service (unbound 1.9.0).
Nov 17 20:11:28 raspberrypi systemd[1]: Started Unbound DNS server.
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: service stopped (unbound 1.9.0).
Nov 17 20:12:46 raspberrypi systemd[1]: Stopping Unbound DNS server...
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: server stats for thread 0: 22 queries, 13 answers from cache, 9
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: server stats for thread 0: requestlist max 6 avg 1.22222 exceedeNov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: average recursion processing time 0.305827 sec
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: histogram of recursion processing times
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: [25%]=0.16384 median[50%]=0.340787 [75%]=0.458752
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: lower(secs) upper(secs) recursions
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: 0.000000 0.000001 2
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: 0.131072 0.262144 1
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: 0.262144 0.524288 5
Nov 17 20:12:46 raspberrypi unbound[527]: [527:0] info: 0.524288 1.000000 1
Nov 17 20:12:46 raspberrypi systemd[1]: unbound.service: Succeeded.
Nov 17 20:12:46 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 17 20:13:49 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 17 20:13:49 raspberrypi package-helper[1446]: [1700244829] unbound-checkconf[1448:0] error: Could not open /etc/unboNov 17 20:13:49 raspberrypi package-helper[1449]: [1700244829] unbound-checkconf[1451:0] error: Could not open /etc/unboNov 17 20:13:49 raspberrypi unbound[1452]: [1700244829] unbound[1452:0] error: Could not open /etc/unbound/unbound.conf:Nov 17 20:13:49 raspberrypi unbound[1452]: [1700244829] unbound[1452:0] warning: Continuing with default config settingsNov 17 20:13:49 raspberrypi unbound[1452]: [1700244829] unbound[1452:0] error: can't bind socket: Address already in useNov 17 20:13:49 raspberrypi unbound[1452]: [1700244829] unbound[1452:0] fatal error: could not open ports
Nov 17 20:13:49 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 17 20:13:49 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 17 20:13:49 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Nov 17 20:13:50 raspberrypi systemd[1]: unbound.service: Service RestartSec=100ms expired, scheduling restart.
Nov 17 20:13:50 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 1.
Nov 17 20:13:50 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 17 20:13:50 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 17 20:13:50 raspberrypi package-helper[1474]: [1700244830] unbound-checkconf[1477:0] error: Could not open /etc/unboNov 17 20:13:50 raspberrypi package-helper[1478]: [1700244830] unbound-checkconf[1481:0] error: Could not open /etc/unboNov 17 20:13:51 raspberrypi unbound[1495]: [1700244831] unbound[1495:0] error: Could not open /etc/unbound/unbound.conf:Nov 17 20:13:51 raspberrypi unbound[1495]: [1700244831] unbound[1495:0] warning: Continuing with default config settingsNov 17 20:13:51 raspberrypi unbound[1495]: [1700244831] unbound[1495:0] error: can't bind socket: Address already in useNov 17 20:13:51 raspberrypi unbound[1495]: [1700244831] unbound[1495:0] fatal error: could not open ports
Nov 17 20:13:51 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 17 20:13:51 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 17 20:13:51 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Nov 17 20:13:51 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 17 20:13:51 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 17 20:13:51 raspberrypi package-helper[1500]: [1700244831] unbound-checkconf[1502:0] error: Could not open /etc/unboNov 17 20:13:51 raspberrypi package-helper[1503]: [1700244831] unbound-checkconf[1505:0] error: Could not open /etc/unboNov 17 20:13:51 raspberrypi unbound[1506]: [1700244831] unbound[1506:0] error: Could not open /etc/unbound/unbound.conf:Nov 17 20:13:51 raspberrypi unbound[1506]: [1700244831] unbound[1506:0] warning: Continuing with default config settingsNov 17 20:13:51 raspberrypi unbound[1506]: [1700244831] unbound[1506:0] error: can't bind socket: Address already in useNov 17 20:13:51 raspberrypi unbound[1506]: [1700244831] unbound[1506:0] fatal error: could not open ports
After a system reboot:
[527:0] error: unable to open /var/lib/unbound/root.key for reading: No such f
Nov 20 11:03:10 raspberrypi unbound[527]: [527:0] error: error reading auto-trust-anchor-file: /var/lib/unbound/root.key
Nov 20 11:03:10 raspberrypi unbound[527]: [527:0] error: validator: error in trustanchors config
Nov 20 11:03:10 raspberrypi unbound[527]: [527:0] error: validator: could not apply configuration settings.
Nov 20 11:03:10 raspberrypi unbound[527]: [527:0] error: module init for module validator failed
Nov 20 11:03:10 raspberrypi unbound[527]: [527:0] fatal error: failed to setup modules
What do below five output?
sudo systemctl cat unbound.service
sudo systemctl stop unbound.service
sudo mv /var/lib/unbound/root.key ~
sudo sh -x /usr/lib/unbound/package-helper root_trust_anchor_update
stat /var/lib/unbound/root.key
[Unit]
Description=Unbound DNS server
Documentation=man:unbound(8)
After=network.target
Before=nss-lookup.target
Wants=nss-lookup.target
[Service]
Type=notify
Restart=on-failure
EnvironmentFile=-/etc/default/unbound
ExecStartPre=-/usr/lib/unbound/package-helper chroot_setup
ExecStartPre=-/usr/lib/unbound/package-helper root_trust_anchor_update
ExecReload=/usr/sbin/unbound-control reload
PIDFile=/run/unbound.pid
[Install]
WantedBy=multi-user.target
+ UNBOUND_CONF=/etc/unbound/unbound.conf
+ dirname /etc/unbound/unbound.conf
+ UNBOUND_BASE_DIR=/etc/unbound
+ unbound-checkconf -o chroot
+ CHROOT_DIR=
+ DNS_ROOT_KEY_FILE=/usr/share/dns/root.key
+ ROOT_TRUST_ANCHOR_FILE=/var/lib/unbound/root.key
+ RESOLVCONF=true
+ ROOT_TRUST_ANCHOR_UPDATE=true
+ [ -f /etc/default/unbound ]
+ . /etc/default/unbound
+ ROOT_TRUST_ANCHOR_UPDATE=false
+ do_root_trust_anchor_update
+ false
stat: cannot stat '/var/lib/unbound/root.key': No such file or directory
It doesnt want to update/create that missing file /var/lib/unbound/root.key.
What does below show?
cat /etc/default/unbound
FYI, I dont have above file on my buster release:
pi@ph5a:~ $ cat /etc/default/unbound
cat: /etc/default/unbound: No such file or directory
ROOT_TRUST_ANCHOR_UPDATE="false"
Any thoughts and how to start a fresh install (reset) unbound, without resetting my entire pihole installation?
Remove that file with:
sudo rm /etc/default/unbound
Run below one again:
Check if that missing file exists now:
If exists, restart:
sudo systemctl restart unbound.service
And check status and journals again:
sudo systemctl status unbound.service
EDIT: Oh and run below one too just to be sure:
Most likey wont need to if above steps work.
File: /var/lib/unbound/root.key
Size: 758 Blocks: 8 IO Block: 4096 regular file
Device: b302h/45826d Inode: 1838074 Links: 1
Access: (0644/-rw-r--r--) Uid: ( 111/ unbound) Gid: ( 118/ unbound)
Access: 2023-11-20 22:02:15.551226929 +0200
Modify: 2023-11-20 22:02:15.551226929 +0200
Change: 2023-11-20 22:02:15.561226920 +0200
Birth: -
Active: active (running) since Mon 2023-11-20 22:02:37 IST; 4s ago
Process: 5464 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 5467 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Main PID: 5471 (unbound)
Tasks: 1 (limit: 2059)
CGroup: /system.slice/unbound.service
└─5471 /usr/sbin/unbound -d
Nov 20 22:02:37 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 20 22:02:37 raspberrypi package-helper[5467]: /var/lib/unbound/root.key has content
Nov 20 22:02:37 raspberrypi package-helper[5467]: success: the anchor is ok
Nov 20 22:02:37 raspberrypi unbound[5471]: [5471:0] info: start of service (unbound 1.9.0).
Nov 20 22:02:37 raspberrypi systemd[1]: Started Unbound DNS server.
-- Logs begin at Mon 2023-11-20 11:03:03 IST, end at Mon 2023-11-20 22:02:52 IST. --
Nov 20 11:12:43 raspberrypi unbound[1183]: [1700471563] unbound[1183:0] error: unable to open root.key for reading: No such file or directory
Nov 20 11:12:43 raspberrypi unbound[1183]: [1700471563] unbound[1183:0] error: error reading auto-trust-anchor-file: root.key
Nov 20 11:12:43 raspberrypi unbound[1183]: [1700471563] unbound[1183:0] error: validator: error in trustanchors config
Nov 20 11:12:43 raspberrypi unbound[1183]: [1700471563] unbound[1183:0] error: validator: could not apply configuration settings.
Nov 20 11:12:43 raspberrypi unbound[1183]: [1700471563] unbound[1183:0] error: module init for module validator failed
Nov 20 11:12:43 raspberrypi unbound[1183]: [1700471563] unbound[1183:0] fatal error: failed to setup modules
Nov 20 11:12:43 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Nov 20 11:12:43 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 20 11:12:43 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Nov 20 11:12:43 raspberrypi systemd[1]: unbound.service: Service RestartSec=100ms expired, scheduling restart.
Nov 20 11:12:43 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 5.
Nov 20 11:12:43 raspberrypi systemd[1]: Stopped Unbound DNS server.
Nov 20 11:12:43 raspberrypi systemd[1]: unbound.service: Start request repeated too quickly.
Nov 20 11:12:45 raspberrypi systemd[1]: unbound.service: Start request repeated too quickly.
Nov 20 11:12:45 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 20 11:12:45 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Nov 20 11:19:03 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 20 11:19:03 raspberrypi unbound[1315]: [1315:0] info: start of service (unbound 1.9.0).
Nov 20 11:19:03 raspberrypi systemd[1]: Started Unbound DNS server.
Nov 20 20:23:14 raspberrypi unbound[1315]: [1315:0] info: service stopped (unbound 1.9.0).
Nov 20 20:23:14 raspberrypi systemd[1]: Stopping Unbound DNS server...
Nov 20 20:23:14 raspberrypi systemd[1]: unbound.service: Succeeded.
Nov 20 20:23:14 raspberrypi systemd[1]: Stopped Unbound DNS server.
unbound-checkconf: no errors in /etc/unbound/unbound.conf
Ok, so now I have a new Unbound installation and the official pihole config, yet the issue persists.
dig sigok.verteiltesysteme.net @127.0.0.1 -p 5335
; <<>> DiG 9.11.5-P4-5.1+deb10u9-Raspbian <<>> sigok.verteiltesysteme.net @127.0.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 44795
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;sigok.verteiltesysteme.net. IN A
sigok.verteiltesysteme.net. 1799 IN CNAME sigok.rsa2048-sha256.ippacket.stream.
sigok.rsa2048-sha256.ippacket.stream. 60 IN A 195.201.14.36
;; Query time: 135 msec
;; WHEN: Mon Nov 20 22:05:23 IST 2023
;; MSG SIZE rcvd: 121
dig e-services.clalit.co.il @127.0.0.1 -p 5335
; <<>> DiG 9.11.5-P4-5.1+deb10u9-Raspbian <<>> e-services.clalit.co.il @127.0.0.1 -p 5335
Up verbosity to 3, reload unbound and tail the journals live when running above dig.
Post results here.
verbosity is up to 3, and restarted unbound using sudo systemctl restart unbound.service
then I ran sudo journalctl --full --follow --priority 4 -u unbound.service
which gives:
-- Logs begin at Mon 2023-11-20 11:03:03 IST. --
Nov 20 11:12:42 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Nov 20 11:12:42 raspberrypi systemd[1]: Failed to start Unbound DNS server.
when running dig e-services.clalit.co.il @127.0.0.1 -p 5335 in a new terminal window, the log doesn't update at all. It still shows the same thing.
Maybe by upping verbosity, you did something wrong .. typo etc.
Check below now:
Dont run that one now, tail live with below:
sudo journalctl --full --follow -u unbound.service
Below are all the equivalent dig queries my unbound instance makes (from the journals) when trying to resolve that e-services.clalit.co.il domain.
I suspect one or more failing to connect for your unbound instance.
pi@ph5a:~ $ ./unbound_check.sh unbound.good.journals | column -t
dig +norecurse @202.12.27.33 . NS IN
dig +norecurse @192.36.148.17 il. A IN
dig +norecurse @192.115.7.53 co.il. A IN
dig +norecurse @192.115.4.235 clalit.co.il. A IN
dig +norecurse @202.12.27.33 net. A IN
dig +norecurse @192.112.36.4 net. A IN
dig +norecurse @192.55.83.30 bezeqint.net. A IN
dig +norecurse @192.41.162.30 bezeqint.net. A IN
dig +norecurse @212.179.7.7 ns3.bezeqint.net. A IN
dig +norecurse @212.179.7.7 ns2.bezeqint.net. A IN
dig +norecurse @192.35.51.30 bezeqint.net. A IN
dig +norecurse @192.115.132.132 ns1.bezeqint.net. A IN
dig +norecurse @212.179.7.7 e-services.clalit.co.il. A IN
dig +norecurse @192.43.172.30 impervadns.net. A IN
dig +norecurse @198.143.61.165 ucetyes.impervadns.net. A IN
dig +norecurse @192.112.36.4 . DNSKEY IN
dig +norecurse @198.41.0.4 _ta-4f66. A IN
dig +norecurse @204.61.216.134 il. DNSKEY IN
dig +norecurse @194.146.106.122 co.il. DS IN
dig +norecurse @194.146.106.122 co.il. DNSKEY IN
dig +norecurse @192.26.92.30 net. DNSKEY IN
dig +norecurse @198.143.63.165 impervadns.net. DNSKEY IN
They all reply on my Raspi (no connection timed out).
Can check the same on your node (copy/paste ENTER).
I know they are allot but thats just how recursive resolvers like unbound do it ![]()
