Can someone help me to construct a regex block that will cover these:
server-18-154-109-69.ord58.r.cloudfront.net
server-18-172-134-120.ord56.r.cloudfront.net
server-18-172-134-2.ord56.r.cloudfront.net
server-18-172-134-49.ord56.r.cloudfront.net
server-18-64-182-171.ord58.r.cloudfront.net
xx-fbcdn-shv-01-ord5.fbcdn.net
DL6ER
#2
Probably something like
^server-.*\.r\.cloudfront\.net$
We will need a few more examples here to avoid creating a filter that might be to broad, otherwise:
^xx-fbcdn-.*\.fbcdn.net$
Thank you. I tried your first one using https://regexr.com/ but nothing matched.
EDITED: I had to remove the ^
and the $
in order to get it to work ... is that expected?
jfb
#4
Thanks for the help. I tried another regex tester and it accepted them with the anchors
system
Closed
#6
