I have a hard coded version of pihole still running on my Raspberry Pi. I see that PiHole 4.0 is released. Does this mean everything is back up and running from previous instances where Dnsmasq was not working well.
I feel like I need to do a fresh install on a fresh SD card as I am not sure if my current version will update properly with the update command.
Can anyone assist, it has been a little bit since I have touched pihole
Current info
Pi-hole Version vDev (HEAD, v3.2.1-0-ge602008) Web Interface Version vDev (HEAD, v3.2.1-0-g31dddd8) FTL Version vDev (v2.13.2 , v2.13.2 )
Awesome. I will try that later tonight or tomorrow. Would there be a point to make a SD 1:1 backup before running the master command or do you think I will be OK?
You guys rule. Thanks for the information. I will mark the topic as 'solved' once I get everything rocking. I will follow up too!
Pumped to get this going, hope I can tomorrow (day off)
OK.
SD card backed up. Going to try using the same card and the update command you said. (fingers crossed). I will post any results if there are questions or something breaks
_**Please note that changing branches severely alters your Pi-hole subsystems**_
_** Features that work on the master branch, may not on a development branch**_
_** This feature is NOT supported unless a Pi-hole developer explicitly asks!**_
_** Have you read and understood this? [y/N]**_
_**[i] Shortcut "master" detected - checking out master branches...**_
_** [i] Pi-hole core**_
_** [✓] Switching to branch: 'master' from 'refs/heads/master'**_
_** [i] Already up-to-date.**_
_** [i] Web interface**_
_** [✓] Detected ARM-hf architecture (armv7+)**_
_** [✓] Installing FTL**_
_** $ pihole -up**_
_** [i] Checking for updates...**_
_** [i] Pi-hole Core: up to date**_
_** [i] FTL: update available**_
_** [i] FTL out of date**_
_** [i] FTL Checks...**_
_** [i] Downloading and Installing FTL...curl: (22) The requested URL returned error: 404 Not Found**_
_** [✗] Downloading and Installing FTL**_
_** Error: URL https://github.com/pi-hole/FTL/releases/download/v4.1/ not found**_
Current PiHole state:
**Pi-hole Version** v4.1 **Web Interface Version** v4.1 **FTL Version** vDev (master , vDev-d42bcb7 )
### FTL Information
The FTL service is offline!
[i] Existing PHP installation detected : PHP version 5.6.33-0+deb8u1
[i] Repair option selected
[✓] Disk space check
[✓] Checking apt-get for upgraded packages... 159 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[✓] Checking for apt-utils
[✓] Checking for dialog
[✓] Checking for debconf
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[i] Performing reconfiguration, skipping download of local repos
[✓] Resetting repository within /etc/.pihole...
[✓] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[✓] Checking for bc
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[i] Checking for sqlite3 (will be installed)
[✓] Checking for libcap2-bin
[i] Checking for dns-root-data (will be installed)
[i] Checking for resolvconf (will be installed)
[✓] Checking for lighttpd
[✓] Checking for php5-common
[✓] Checking for php5-cgi
[✓] Checking for php5-sqlite
[✓] Enabling lighttpd service to start on reboot...
[✓] Installing scripts from /etc/.pihole
[✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Installing blocking page...
[✓] Creating directory for blocking page, and copying files
[✗] Backing up index.lighttpd.html
[✓] Installing sudoer file
[✓] Installing latest Cron script
[✓] Installing latest logrotate script
[i] FTL Checks...
Error: Unable to get latest release location from GitHub
[✗] FTL Engine not installed
[✓] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[✓] Starting lighttpd service...
[i] Restarting services...
[✓] Enabling pihole-FTL service to start on reboot...
[✓] Starting pihole-FTL service...
[✓] Deleting existing list cache
[i] Target: raw.githubusercontent.com (hosts)
[i] Target: mirror1.malwaredomains.com (justdomains)
[i] Target: sysctl.org (hosts)
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[✓] Consolidating blocklists
[✓] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 159551
[✓] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 136324
[i] Number of whitelisted domains: 10
[i] Number of blacklisted domains: 4
[i] Number of regex filters: 1
[✓] Parsing domains into hosts format
[✓] Cleaning up stray matter
[✓] Force-reloading DNS service
[✓] DNS service is running
[i] Pi-hole blocking will be enabled
[i] Enabling blocking
[✓] Reloading DNS service
[✓] Pi-hole Enabled
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v4.1
Current AdminLTE version is v4.1
Current FTL version is vDev-d42bcb7
OK so I rebooted after the repair and SSH into the pi
ran
pihole -up
and here is the output
[i] Performing unattended setup, no whiptail dialogs will be displayed
[✓] Checking for bc
[✓] Checking for sqlite3
[✓] Checking for resolvconf
[i] FTL Checks...
[✓] Downloading and Installing FTL
[i] FTL can now resolve DNS Queries without dnsmasq running separately
[✓] Stopping dnsmasq service...
[✓] Disabling dnsmasq service...
[i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
Update Complete!
Current FTL version is v4.1
Pihole Current State:
**Pi-hole Version** v4.1 **Web Interface Version** v4.1 **FTL Version** v4.1
So I think I got it, guess it took
pihole checkout master
reboot
pihole -r
reboot
pihole -up
reboot
Success ???
I think I am good to go, are there any other settings I should be checking ?
There are a number of new features in V4.1 compared to your previous version. The documentation is a good read. Follow the menus on the left of the referenced page.
Awesome!
Thanks. I will do some reading... I already see improvement testing various news (ad) sites. Thanks for all the help. I think I am going to donate to the cause, this app is so dam good. Community is even better !
