EDIT: (solution see below)
I don't think pi-hole is picking up any of my computer's requests (shows 0 queries, 0 blocked etc... on the pi-hole admin page)
My docker-compose.yml (Note port mapping 8080:80):
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp"
- "8080:80/tcp"
environment:
TZ: 'America/Chicago'
WEBPASSWORD: '...'
volumes:
- './etc-pihole/:/etc/pihole/'
- './etc-dnsmasq.d/:/etc/dnsmasq.d/'
# Recommended but not required (DHCP needs NET_ADMIN)
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
cap_add:
- NET_ADMIN
restart: unless-stopped
I've set up my wifi connection DNS address to my raspberry pi IP by following these instructions:
Linux
In most modern Linux distributions, DNS settings are configured through Network Manager.
- Click System > Preferences > Network Connections
- Select the connection for which you want to configure
- Click Edit
- Select the IPv4 Settings or IPv6 Settings tab
- If the selected method is Automatic (DHCP), open the dropdown and select Automatic (DHCP) addresses only instead. If the method is set to something else, do not change it.
- In the DNS servers field, enter your Pi's IP addresses
- Click Apply to save the change
- Repeat the procedure for additional network connections you want to change.
- If your distribution doesn't use Network Manager, your DNS settings are specified in
/etc/resolv.conf
Generate debug log output:
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2021-08-22:21:32:58 debug log has been initialized.
[i] Core: v5.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/pi-hole (fetch)
origin https://github.com/pi-hole/pi-hole (push)
[i] Branch: master
[i] Commit: v5.3.1-0-g4736e031
[i] Web: v5.5.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/adminLTE (fetch)
origin https://github.com/pi-hole/adminLTE (push)
[i] Branch: master
[i] Commit: v5.5.1-0-gfb9bd561
[✓] FTL: v5.8.1
[i] 1.4.53
[i] 7.3.29
[i] dig return code: 0
[i] dig response: "Raspbian=9,10 Ubuntu=16,18,20 Debian=9,10 Fedora=32,33 CentOS=7,8"
[✓] Distro: Debian
[✓] Version: 10
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[✓] Firewalld service not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
172.20.0.2/16 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[✗] No IPv6 address(es) found on the eth0 interface.
[i] Default IPv4 gateway: 172.20.0.1
* Pinging 172.20.0.1...
[✓] Gateway responded.
[53] is in use by pihole-FTL
[✓] go.is.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] go.is.com is 0.0.0.0 via Pi-hole (0.0.0.0)
[✓] doubleclick.com is 142.251.33.78 via a remote, public DNS server (8.8.8.8)
Timeout: 10 seconds
DHCP packets received on interface eth0: 0DHCP packets received on interface lo: 0
[✗] lighttpd daemon is inactive
[✗] pihole-FTL daemon is inactive
*** [ DIAGNOSING ]: Pi-hole-FTL full status
[i] systemctl: command not found
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
IPV4_ADDRESS=0.0.0.0
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
PIHOLE_INTERFACE=eth0
QUERY_LOGGING=true
BLOCKING_ENABLED=true
HTTP/1.1 200 OK
Expires: Sun, 22 Aug 2021 21:33:12 GMT
Cache-Control: max-age=0
Date: Sun, 22 Aug 2021 21:33:12 GMT
Server: lighttpd/1.4.53
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity List and Database
-rw-rw-r-- 1 pihole pihole 5201920 Aug 22 21:10 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 14
updated 1629666633
gravity_count 87094
Last gravity run finished at: Sun Aug 22 21:10:33 UTC 2021
----- First 10 Gravity Domains -----
localhost.localdomain
wizhumpgyros.com
coccyxwickimp.com
n2019cov.000webhostapp.com
webmail-who-int.000webhostapp.com
010sec.com
01mspmd5yalky8.com
0byv9mgbn0.com
ns6.0pendns.org
dns.0pengl.com
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2021-08-22 21:10:31 2021-08-22 21:10:31 The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2021-08-22 21:10:31 2021-08-22 21:10:31 Migrated from /etc/pihole/adlists.list
-rw-r--r-- 1 root root 37 Aug 22 21:10 /etc/pihole/local.list
0.0.0.0 599894f657c9
0.0.0.0 pi.hole
-rw-r--r-- 1 pihole pihole 0 Aug 22 21:10 /etc/pihole/pihole-FTL.conf
-rw-r--r-- 1 root root 1385 Aug 22 21:10 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=eth0
server=/use-application-dns.net/
-rw-r--r-- 1 root root 0 Aug 22 21:10 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 4066 Aug 22 21:10 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = (
"application/json",
"application/vnd.ms-fontobject",
"application/xml",
"font/eot",
"font/opentype",
"font/otf",
"font/ttf",
"image/bmp",
"image/svg+xml",
"image/vnd.microsoft.icon",
"image/x-icon",
"text/css",
"text/html",
"text/javascript",
"text/plain",
"text/xml"
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ "\.(eot|otf|tt[cf]|woff2?)$" {
url.access-deny = ("")
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1755 Aug 4 18:43 /etc/cron.d/pihole
20 3 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
18 13 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 5450 Aug 22 21:19 /var/log/lighttpd/error.log
-----head of error.log------
2021-08-22 16:10:31: (server.c.1464) server started (lighttpd/1.4.53)
2021-08-22 16:14:45: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:14:45: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:14:45: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:14:55: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:14:55: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:14:55: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:15:02: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:15:02: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:15:02: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:15:21: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:15:21: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:15:21: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:15:33: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:15:33: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:15:33: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:15:51: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:15:51: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:15:51: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:18:13: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:18:13: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:18:13: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:19:00: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:19:00: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:19:00: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
-----tail of error.log------
2021-08-22 16:19:31: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:19:31: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:19:31: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:19:36: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:19:36: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:19:36: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
2021-08-22 16:19:40: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
2021-08-22 16:19:40: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
2021-08-22 16:19:40: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
-rw-r--r-- 1 pihole pihole 19796 Aug 22 21:32 /var/log/pihole-FTL.log
[2021-08-22 16:10:29.323 338M] Using log file /var/log/pihole-FTL.log
[2021-08-22 16:10:29.323 338M] ########## FTL started! ##########
[2021-08-22 16:10:29.323 338M] FTL branch: master
[2021-08-22 16:10:29.324 338M] FTL version: v5.8.1
[2021-08-22 16:10:29.324 338M] FTL commit: b90ab8b1
[2021-08-22 16:10:29.324 338M] FTL date: 2021-04-21 20:03:47 +0100
[2021-08-22 16:10:29.324 338M] FTL user: root
[2021-08-22 16:10:29.324 338M] Compiled for armv7hf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2021-08-22 16:10:29.324 338M] Creating mutex
[2021-08-22 16:10:29.326 338M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2021-08-22 16:10:29.326 338M] SOCKET_LISTENING: only local
[2021-08-22 16:10:29.326 338M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2021-08-22 16:10:29.326 338M] MAXDBDAYS: max age for stored queries is 365 days
[2021-08-22 16:10:29.326 338M] RESOLVE_IPV6: Resolve IPv6 addresses
[2021-08-22 16:10:29.326 338M] RESOLVE_IPV4: Resolve IPv4 addresses
[2021-08-22 16:10:29.326 338M] DBINTERVAL: saving to DB file every minute
[2021-08-22 16:10:29.326 338M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2021-08-22 16:10:29.326 338M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2021-08-22 16:10:29.326 338M] PRIVACYLEVEL: Set to 0
[2021-08-22 16:10:29.326 338M] IGNORE_LOCALHOST: Show queries from localhost
[2021-08-22 16:10:29.326 338M] BLOCKINGMODE: Null IPs for blocked domains
[2021-08-22 16:10:29.326 338M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2021-08-22 16:10:29.326 338M] DBIMPORT: Importing history from database
[2021-08-22 16:10:29.326 338M] PIDFILE: Using /run/pihole-FTL.pid
[2021-08-22 16:10:29.327 338M] PORTFILE: Using /run/pihole-FTL.port
[2021-08-22 16:10:29.327 338M] SOCKETFILE: Using /run/pihole/FTL.sock
[2021-08-22 16:10:29.327 338M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2021-08-22 16:10:29.327 338M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2021-08-22 16:10:29.327 338M] GRAVITYDB: Using /etc/pihole/gravity.db
[2021-08-22 16:10:29.327 338M] PARSE_ARP_CACHE: Active
[2021-08-22 16:10:29.327 338M] CNAME_DEEP_INSPECT: Active
[2021-08-22 16:10:29.327 338M] DELAY_STARTUP: No delay requested.
[2021-08-22 16:10:29.327 338M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2021-08-22 16:10:29.327 338M] NICE: Cannot change niceness to -10 (permission denied)
[2021-08-22 16:10:29.328 338M] MAXNETAGE: Removing IP addresses and host names from network table after 365 days
[2021-08-22 16:24:09.029 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:24:39.492 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:24:39.504 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:25:09.914 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:25:09.914 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:25:40.238 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:25:40.238 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:26:10.638 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:26:10.638 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:26:40.886 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:26:40.887 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:27:11.276 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:27:11.277 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:27:41.699 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:27:41.700 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:28:12.105 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:28:12.106 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:28:42.378 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:28:42.378 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:29:12.708 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:29:12.709 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:29:43.149 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:29:43.149 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:30:13.557 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:30:13.558 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:30:43.989 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:30:43.989 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:31:14.391 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:31:14.391 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:31:44.818 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:31:44.819 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:32:15.255 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:32:15.255 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
[2021-08-22 16:32:45.692 440M] FATAL: Trying to access query ID 0, but magic byte is 0
[2021-08-22 16:32:45.692 440M] found in findQueryID() (/root/project/src/datastructure.c:58)
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 root root 684032 Aug 22 21:10 /dev/shm/FTL-clients
-rw------- 1 root root 224 Aug 22 21:10 /dev/shm/FTL-counters
-rw------- 1 root root 4096 Aug 22 21:10 /dev/shm/FTL-dns-cache
-rw------- 1 root root 4096 Aug 22 21:10 /dev/shm/FTL-domains
-rw------- 1 root root 28 Aug 22 21:10 /dev/shm/FTL-lock
-rw------- 1 root root 12288 Aug 22 21:10 /dev/shm/FTL-overTime
-rw------- 1 root root 4096 Aug 22 21:10 /dev/shm/FTL-per-client-regex
-rw------- 1 root root 229376 Aug 22 21:10 /dev/shm/FTL-queries
-rw------- 1 root root 12 Aug 22 21:10 /dev/shm/FTL-settings
-rw------- 1 root root 81920 Aug 22 21:10 /dev/shm/FTL-strings
-rw------- 1 root root 28672 Aug 22 21:10 /dev/shm/FTL-upstreams
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
*** [ DIAGNOSING ]: Locale
LANG=
-rw-r--r-- 1 pihole pihole 7901 Aug 22 21:33 /var/log/pihole.log
-----head of pihole.log------
Aug 22 16:10:29 dnsmasq[340]: started, version pi-hole-2.85 cachesize 10000
Aug 22 16:10:29 dnsmasq[340]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset auth cryptohash DNSSEC loop-detect inotify dumpfile
Aug 22 16:10:29 dnsmasq[340]: using only locally-known addresses for domain use-application-dns.net
Aug 22 16:10:29 dnsmasq[340]: using nameserver 8.8.4.4#53
Aug 22 16:10:29 dnsmasq[340]: using nameserver 8.8.8.8#53
Aug 22 16:10:31 dnsmasq[440]: started, version pi-hole-2.85 cachesize 10000
Aug 22 16:10:31 dnsmasq[440]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset auth cryptohash DNSSEC loop-detect inotify dumpfile
Aug 22 16:10:31 dnsmasq[440]: using only locally-known addresses for domain use-application-dns.net
Aug 22 16:10:31 dnsmasq[440]: using nameserver 8.8.4.4#53
Aug 22 16:10:31 dnsmasq[440]: using nameserver 8.8.8.8#53
Aug 22 16:10:31 dnsmasq[440]: read /etc/hosts - 7 addresses
Aug 22 16:10:31 dnsmasq[440]: read /etc/pihole/custom.list - 0 addresses
Aug 22 16:10:31 dnsmasq[440]: failed to load names from /etc/pihole/local.list: No such file or directory
Aug 22 16:10:33 dnsmasq[440]: read /etc/hosts - 7 addresses
Aug 22 16:10:33 dnsmasq[440]: read /etc/pihole/custom.list - 0 addresses
Aug 22 16:10:33 dnsmasq[440]: read /etc/pihole/local.list - 2 addresses
Aug 22 16:10:34 dnsmasq[440]: read /etc/hosts - 7 addresses
Aug 22 16:10:34 dnsmasq[440]: read /etc/pihole/custom.list - 0 addresses
Aug 22 16:10:34 dnsmasq[440]: read /etc/pihole/local.list - 2 addresses
Aug 22 16:10:57 dnsmasq[440]: query[A] pi.hole from 127.0.0.1
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* Log will NOT be uploaded to tricorder.
* A local copy of the debug log can be found at: /var/log/pihole_debug.log
Any ideas? Thanks
