How do you edit to make a code block?
Enclose it with this charracter:
So like this:
`Some
code`
Will look like:
Some code
Button on top of editor that looks like this <<>/> does same.
Was bored waiting for apt uprade (jessie to stretch):
0,30 * * * * [[ $(echo "scale=0; $(ps u -p $(pidof pihole-FTL) | grep -v USER | awk '{print $4}')*1/1" | bc -l) -ge 50 ]] && (echo "$(date +'[%F %H:%M:%S:%3N]') Warning: Memory exceeded 50% ... RESTARTING pihole-FTL" >> /var/log/pihole-FTL.log; /usr/sbin/service pihole-FTL restart) >&2>&1
EDIT: cant test bc seems I dont have this leak.
The problem is that when I use valgrind to run pihole-FTL then then pihole web interface find pihole-FTL not running (red icon and "FTL offline" message is displayed in Pi-hole Admin Console) then the memory leak don't appear. The issue only appear when web interface is open, used logged in and is communicating with pihole-FTL.
Best Regards,
Hello,
Well, finally I got valgrind running. I created a dummy process called pihole-FTL after running valgrind to fool pihole web interface so it detect pihole-FTL running. After few minutes I see memory usage growing. The valgrind output is:
==10984== HEAP SUMMARY:
==10984== in use at exit: 10,545,748 bytes in 226 blocks
==10984== total heap usage: 4,127 allocs, 3,901 frees, 19,193,868 bytes allocated
==10984==
==10984== 3,400,000 bytes in 34 blocks are definitely lost in loss record 20 of 21
==10984== at 0x482F0B8: calloc (in /usr/lib/valgrind/vgpreload_memcheck-x86-linux.so)
==10984== by 0x11271F: read_setupVarsconf (setupVars.c:58)
==10984== by 0x110058: getTopClients (request.c:403)
==10984== by 0x111DC7: process_request (request.c:59)
==10984== by 0x10EDB6: connection_handler_thread (socket.c:213)
==10984== by 0x4847294: start_thread (pthread_create.c:333)
==10984== by 0x4944EED: clone (clone.S:114)
==10984==
==10984== 6,700,000 bytes in 67 blocks are definitely lost in loss record 21 of 21
==10984== by 0x10FAC8: getTopDomains (request.c:323)
==10984== by 0x111D81: process_request (request.c:54)
==10984==
==10984== LEAK SUMMARY:
==10984== definitely lost: 10,100,000 bytes in 101 blocks
==10984== indirectly lost: 0 bytes in 0 blocks
==10984== possibly lost: 0 bytes in 0 blocks
==10984== still reachable: 445,748 bytes in 125 blocks
==10984== suppressed: 0 bytes in 0 blocks
The problem seems that is at: getTopClients and getTopDomains, there is a 100.000 byte calloc that is lost in each call.
Best Regards,
I've been running into the same problem.
Thanks for identifying this! Apparently, I just missed one free()
call in read_setupVarsconf()
I'm at the airport and put together a bugfix for this misbehavior:
FTL v2.6.1
should then be released soon.
2.6.1 installed; Lost connection to API after half a minute or so. Reproducable.
We know what is going on. v2.6.2
is already in the pipeline and is currently undergoing quality tests and build integration.
Please update to FTL v2.6.2
which fixes a double-free
issue I accidentally introduced that affected users that have never set any domains and/or clients to be excluded on the Settings page.
Updated to 2.6.2.
So far all seems ok. FTL daemon not crashing and memory usage not growing.
Good work.
Best Regards,
Updated one of my pi-holes. Will see how it does overnight and then do the main one.
FTL 2.6.2 looks good now. Thnx!!
