Ajuda com configuração do Pi-hole com DNS Unbound pela porta 5353. Grato
Help with configuration of Pi-hole with DNS Unbound on port 5353. Thanks
Sim, mais no website Redirecting... informa que apenas colocar o 127.0.0.1#5353, mais a realidade não deixa colocar 127.0.0.1 #5353 fica 127.0.0.153. Poderia me ajudar. Grato
Pi-hole Version v3.3.1 Web Interface Version v3.3 FTL Version v3.0
Yes, more on the website Redirecting... informs you that only put 127.0.0.1 # 5353, but reality does not let 127.0.0.1 # 5353 get 127.0.0.153. Would you help me. GrateHelp with Pi-hole configuration with DNS Unbound over port 5353. Thanks
Yes the doc site is intended for 4.0. To use this feature you need to run pihole checkout dev
which will then allow you to put 127.0.0.1#5353
in as a custom upstream resolver
Olá! technicalpyro Muito Grato Este comando (run pihole checkout dev ) funcionou! Muito Grato!
Hello! technicalpyro Very grateful This command (run pihole checkout dev ) worked! Much obliged!
De nada, que tengas un gran día
