Ads occasionally get by in pop-ups and banners
Is there a good way of identifying the providing server?
My basic install is working very well and Gravity is up to date.
I am trying to take a more of a scalpel approach, than a sledgehammer.
Is that better or is adding a few hundred or thousand domains via additional lists not a big of a deal?
Thank You!!
@Mcat12
NSThingy Whitelist Assistant is pretty much exactly what I was looking for.
Good call on the FAQ Link.
Hopefully, an easy follow-up question:
It showed the inspect function in chrome, which is neat but is there a way to make it function opposite?
like hover over the web pane and it would highlight the code on the other pane?
I could probably scrape it and run it local; but that's pretty iffy and a lot of work for a stray banner ad or whatever.
