I am attempting to have each client's activity show up in Pi-Hole.
My original setup was where I had a Netgear R7000 flashed with FreshTomato and in dnsmasq, I added the custom setting dhcp-option=6,192.168.1.38
and 192.168.1.38
is my Odroid HC2 server internal IP address. My router's gateway was the basic 192.168.1.1
. I had OpenDNS DNS addresses set up in my router (not Pi-Hole). I also had OMV (OpenMediaVault) GUI accessible on 192.168.1.38:81
. In Pi-Hole > Settings > DNS, I had Custom ipv4 checked and the address was 192.168.1.1
(my router). Respond only on interface eth0
was checked off, as well as Use Conditional Forwarding with the CIDR 192.168.1.0/24
and IP address of your DHCP server (router) 192.168.1.1
Everything worked fine this way and I could see individual client activity. Recently, my server died so I had to reinstall everything on a new server. I did not want to change OMV to be on port 81
. I wanted to keep it on port 80
. So I changed Pi-Hole to be port 81
. The problem is, I don't know what to put in my router. For example, in dnsmasq, I tried dhcp-option=6,192.168.1.38:81
but then I could no longer browse (connect to?) the internet. So I changed back to dhcp-option=6,192.168.1.38
and I don't see individual client activity in Pi-Hole. Is it possible to make my setup work with Pi-Hole on port 81
of 192.168.1.38
and keep my router handling DNS?
