I had an idea for a Pi-Hole feature. In the web UI there's a little panel that shows which domains are most blocked on your network. Here's what mine looks like:
What if the clients could optionally share their list of Top Blocked Domains, so there was sort of a "global leaderboard" of the most commonly blocked domains out there, maybe fastest rising newly blocked domains, things like that?
It'd be a way of building collective intelligence on problem domains, perhaps?
And on the opposite side, if some domains are basically never blocked, they could be dropped from the lists over time as useless or ineffective, so the domain block lists could be kept cleaner?
