SERVFAIL with unbound
The pasted image of the output shows some settings that are not present in the unbound configuration guide at Redirecting...
From "so-reuseport" down through "so-recbuf" are different or do not appear in the pi-hole setup guide. Why have you used these settings?
Your full configuration is shown in your screen snap.
I see that your settings for so_reuseport, msg-cache-size and rrset-cache-size are the defaults.
Your num-tcp settings are significantly higher than the defaults.
This is a screen shot of the settings recommended by the Pi-Hole guide. These do not match your settings in some respects, as noted above.
Ok, then I will return the TCP amount later, or delete it, but I don't think it has anything to do with this! hope so!
We are a Pi-Hole forum and can only offer limited advice on unbound, since the developers don't write that code. I recommend going into the unbound forums to find out what causes SERVFAILs.
I am a little busy late to reply to your test results! Thank you for your guidance!
Can the unbound forum address be given to me?
Google is a good resource. NLnet Labs - Unbound - Support
thk you !!!
The unbound forum has no feedback, only the mail can communicate.
Ok, I am trying to upgrade unbound.
root@rockpi:/opt# unbound -h
usage: unbound [options]
start unbound daemon DNS resolver.
-h this help
-c file config file to read instead of /etc/unbound/unbound.conf
file format is described in unbound.conf(5).
-d do not fork into the background.
-v verbose (more times to increase verbosity)
Version 1.6.7
linked libs: libevent 2.1.8-stable (it uses epoll), OpenSSL 1.1.0g 2 Nov 2017
linked modules: dns64 python subnetcache respip validator iterator
BSD licensed, see LICENSE in source package for details.
Report bugs to unbound-bugs@nlnetlabs.n
I did not install dnscryptproxy, just a pi hole and unbound
root@rockpi:~# uname -sm
Linux aarch64
How to update the version of this system
I am testing if I have dnscryptproxy installed.
I used this tutorial to install and configure unbound
https://docs.pi-hole.net/guides/unbound/
