2 Samsung Smartcam's should have a green LED and I should be able to view their live feed.
2 Samsung Smartcam's have a blue LED indicating they're ready for setup and I cannot connect to them. If I disable Pi-Hole they reconnect. There is no logged activity for them what-so-ever on the Pi-Hole. Service provider ONT/Gateway is handling DHCP and both devices have an IP and can be pinged.
Initially I was looking in the Query Log and there are only a couple entries from one of the cameras with domains of "+.home" and "+". I've now looked at /var/log/pihole.log and the camera's only entries in there just show their IP address and the word cached. No outbound address is listed. With Wireshark running I don's see any traffic coming out of the cameras at all.
If that is the IP of the camera, then the camera was not making the request. Something was requesting the IP of the camera. The line above that in the log will show the requesting client. Typically you will see this pattern - query, followed by forward if not cached, then reply.
May 19 19:31:57 dnsmasq[2365]: query[A] d.dropbox.com from 192.168.0.135
May 19 19:31:57 dnsmasq[2365]: forwarded d.dropbox.com to 127.0.0.1
May 19 19:31:57 dnsmasq[2365]: reply d.dropbox.com is <CNAME>
May 19 19:31:57 dnsmasq[2365]: reply d.v.dropbox.com is <CNAME>
May 19 19:31:57 dnsmasq[2365]: reply d-sjc.v.dropbox.com is 162.125.34.137
