i have run pihole quiet long, but today i have problem with my router and rpi.
So i need to reinstall both router and rpi.
router = 192.168.1.1
rpi=192.168.1.84
network config
so i plug my 4g usb modem on my router(openwrt).
i want rpi act both as dns server and dhcp server so i wired rpi to router using ethernet port.
i run pihole instalation script on rpi. once its complete.
i enable dhcp server on rpi, then i go to my router setting to put my rpi's ip.
and disable dhcp server.
problem is i dont know whether my system is correct or not.
It blocks the ads, it seems normal.
then i run ping and nslookup, it shows normal output.
but when i run traceroute, it gives me time out (*) all 30 hops.
pi@raspberrypi:~ $ dig detik.com
; <<>> DiG 9.9.5-9+deb8u10-Raspbian <<>> detik.com ;; global options: +cmd ;; Got answer:;; OPT PSEUDOSECTION: ; EDNS: version: 0, flags:; udp: 4096 ;; QUESTION SECTION: ;detik.com. IN A
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 21096
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;; ANSWER SECTION: detik.com. 104 IN A 103.49.221.211 detik.com. 104 IN A 203.190.242.211
;; Query time: 84 msec ;; SERVER: 127.0.0.1#53(127.0.0.1) ;; WHEN: Wed May 03 00:37:09 WIB 2017 ;; MSG SIZE rcvd: 70
pi@raspberrypi:~ $ nslookup detik.com Server: 127.0.0.1 Address: 127.0.0.1#53
Non-authoritative answer: Name: detik.com Address: 203.190.242.211 Name: detik.com Address: 103.49.221.211
pi@raspberrypi:~ $ traceroute detik.com traceroute to detik.com (103.49.221.211), 30 hops max, 60 byte packets 1 192.168.1.1 (192.168.1.1) 0.473 ms 0.489 ms 0.492 ms 2 * * * 3 * * * 4 * * * 5 * * * 6 * * *
does it look normal?
Thanks.
