can you run pi hole on more than 1 wi-fi network?
Not sure what you want to do here. I assume your Pi has a single WiFi connection available, in which case you won't be able to simultaneously connect it to both networks.
If you have two WiFi networks, they will have different SSIDs? Not bridged together in any way?
there will be different SSIDs and are not bridged together at all.
Give it a try, let us and the community know what you find out!
If the SIDD's have different subnets, you could connect Pi-hole to both WiFi networks.
A Raspberry Pi with on-board WiFi would only require an extra USB WiFi dongle.
