So I want to set my folks up with a pi-hole on a zero. I was thinking of using Resin.io, which deploys apps in docker containers for mass deployment.
The cool part is I could maintain their system and maybe just maybe replace their ads with Nicholas Cage pictures once in a while.
Using an existing Docker image (https://github.com/diginc/docker-pi-hole), I got it pi-hole up and running through Resin (the only code is needed is FROM diginc/pi-hole:arm
in a Dockerfile!)
The big issue is that Resin uses port 53 for DNS resolution and 80 for a web file server. I can see the pi-hole dashboard, but it cannot function as a DNS server. The console feed includes dnsmasq: failed to create listening socket for port 53: Address already in use
The docker-pi-hole page linked above has a solution to rerouting ports but it involves a multi-container reverse proxy using nginx and now I'm getting in over my head.
Is there a simpler fix for getting the ports to work? I'm starting to think I should abandon the Resin idea and just install pi-hole the old fashioned way.
