Hello, I have RPi 3B+ with Rasbian Stretch + Pihole. I wanted also use sometimes Rasbian to watch movies online and here is problem because I can't. Almost all movies stop after some minutes. Any other device in my network work without problems.
i doubt this would have anything to do with Pi-hole. if it did it wouldnt work on any device using Pi-hole as its DNS. assuming you are using kodi i do not know why but it may be a heat thing from processing etc
I agree with @technicalpyro that this is not likely a Pi-Hole issue. Pi-Hole puts very little demand on a 3B+ (Pi-Hole and unbound together on a 3B+ load the CPU to about 5% at most).
Have you run this 3B+ without PiHole, and if so, were you able to watch movies on it?
thanks fpr replies. I know that it isn't Pi-hole fault. Probably something wrong with chromium in Raspian Stretch because this I tried to use.
any other devices work very well with working Pi-hole.
