Did everything except DNS cache, theres no option for it on my modem.
Redid dhcp, I cant even pull an IP, yes this point to modem issue. As soon as I statically set an IP I have good connectivity but the net is slow, nslookup is showing pihole as DNS. Traceroute comes back super slow.
I gave DHCP back to the modem, started an update on the lists I have for my pi at 19:43, its 19:55 and its still not done. Actually just finished at :56, All retrievals successful minus one.
The pi blocking is running extremely slow. I am now at 1.5m blocklist and after about 5 minutes of decent browsing (as I am writing my girlfriend is on her phone doing pinterest, I am taking breaks too googling around) 3, yes three, queries are blocked and yes were both on wifi via the modem.
I am not sure what else to do at this point to be honest.
Here is something I noticed:
Pi-hole Ethernet Interface:|wlan0|
Pi-hole IPv4 address:|192.168.1.13/24|
Pi-hole IPv6 address:||
Pi-hole hostname:pi
That is from the GUI, why does it think the ip is 192.168.1.13/24 on wlan0 (wireless) when:
~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.0.30
A couple more minutes of browsing and a total of 5 blocked domains this time... Yeah somethings up. I notice all the IPs are also coming from 10.0.0.1 instead of their assigned ips.
The cable company is sending me a new modem. I am going to put that in and configure it and we will go from there seeing as nobody here even wants to start looking at my pi.
I have done it via static dns on the device itself and forced it through the modem (done it together so both the device and modem have it, I have also done it where just the modem has it and just where the device has it).
After browsing the net some more on pinterest, ebaums world and just random sites to try and get ads for like 20 more minutes and let the net just be overnight, it went up a total of about 20 blocks. Before the router died I was in the ~60% blocking range and now I am less than 10 with roughly the same amount of DNS's on my blocklist.
I believe everybody says its my modem, I agree it most likely is. Just want to figure out why and that may be too off topic for this forum. On the main page of the modem it says the DNS is statically set to .30, the dynamic is grayed out. Its possible they have some override code in the background I just wont see. I got an update and I am getting a 2200 instead of a 3200 today. If I get that setup Ill update later unless somebody chimes in with a question.
Thats because I dont suspect anything wrong with Pi as you told us before switching modem/router, you didnt experience any issues.
When the new router arrives, can you post screenshots of all settings related to DNS and DHCP ?
Lets turn you into a Pi-hole expert and try set it up the proper way.
The proper way, if possible with available router settings, is to have the routers DHCP service hand out Pi-hole's IP address as the only DNS server to the clients:
If router DHCP server settings lacking/missing, you can switch off the DHCP service on the router and activate Pi-hole's DHCP service as a replacement.
As a very last resort and not a desired solution, you can configure the router to use Pi-hole as upstream DNS resolver (usually called WAN DNS or something).
But with that last one, you miss out on nice client statistics as all the DNS requests are coming from the router instead of the clients (from Pi-hole's perspective).
Alright something strange happened while I was at work yesterday.
First off the modem has not arrived yet. So I havent touched anything BUT... I noticed all the ips the day before yesterday were coming from .1, the modem. I get home last night and start looking through things and see they are now all coming from .10-.29, which is what I have blocked off for my home network and theres no more slowdowns that I noticed. I think Ill keep things running the way they are now and after a little bit switch the dhcp over to the pi.
The block rate has risen a little bit, from <10% to about 30% now which is better, but not as great as when it was around 60%.
The only explanation I have for this is that maybe there is a cache inside the modem that cannot be cleared? I have no idea its strange.
30% blocked sounds healthy and is exactly the same as on my Pi.
Keep in mind that DHCP client leases have a lease duration similar as the TTL (Time To Live) on DNS records.
You can see when a client got its lease, from whom it got the lease, and when it expires with the ipconfig /all command run on the game rig (I presume its Windows).
If want to stick with the current router/modem, you could post screenshots of current DNS & DHCP settings on the router for us to have a look ?
What specific features do you need when you change stuff; IP range, passthrough, dhcp, etc.?
Unless there is something in particular, don't change any of the modems settings! Most of your issues are related to settings that are perhaps wrong? I suggest you work fresh with modem / rasbian reinstalled to get the basic dns ad blocking to work.
