Problem with Beta 5.0:
Some requests are being forwarded to my router (configured as Conditional Forwarding for ".local" domains).
I noticed that this happened (right now) during the FTL upgrade, however, looking at recent queries forwarded to the router I realized that it has eventually been used as upstream.
This is strange, however, one possible reason could be that we had an issue with forward destinations even causing crashes on Pi-hole around yesterday and the day before. Can you ensure that you are on the most recent version of Pi-hole beta and then check again if this still happens?
I'm asking this as data recorded while the bug was in the code cannot necessarily be trusted so only newly generated queries (and even after ensuring you're already up-to-date) should be trusted.
YES however when happening to me I get flooded with PTR requests.
2020-02-12 14:30:00 PTR lb._dns-sd._udp.0.2.168.192.in-addr.arpa ddwrt OK (forwarded)
UNKNOWN N/A
Its almost like somehow i have a loop or something once in awhile.
Could it somehow be when a client drops off unexpectedly and it is being actively looked for?
Example: when my tv/roku powers and the wifi remote is still looking for it?
the client ddwrt is 192.168.1.2 the 192.168.2.0 (192.168.2.2) is ddwrt1
they are on separate vlans/subnets one is a guest network isolated other than port 53 to pihole
see 192.168.1.2 to has full abilities to 192.168.2.x not the other way around. dhcp is handled by 192.168.1
Could be as simple as ports for dhcp. I will play around if it happens again.
