(pihole just updated, working through the webinterface)
I added a new regex to the blacklist, and updated gravity
The regex is imported and domains are filtered using that.
Relevant output from gravity:
[i] Number of whitelisted domains: 12
[i] Number of blacklisted domains: 0
[i] Number of regex filters: 0
domains matching the regex are not filtered
checking /etc/pihole/regex.list shows the lines, of which the webinterface said the regex was correct:
root@server:~# cat /etc/pihole/regex.list
r\d+-+sn-[\w-]+\.googlevideo.com
root@server:~#
(making the regex progressively more simple doesn't change the described behaviour)
[✓] Your debug token is: 3ut874j5wn
