My raspberry PI listened to 192.168.2.50 (static IP) but in addition I had setup a Bonding interface (bond0) which had as slaves Eth0 and Wlan0. This configuration worked flawlessly for more than 2 years. Bond0 interface had the static IP 192.168.2.50 and the slave interfaces worked like physical mediums to the virtual bonding interface. I expected to have the same network setup after installing the pi-hole
After installing pi-hole my network setup is a complete mess. Currently bond interface has no IP and instead the other two interface work in DHCP mode and take an IP from the DHCP server. Every connection to my raspberry is not possible through IP despite that both interface are being assigned an IP so I am forced to login using the serial port of the PI.
[Replace this text with the debug token provided from running pihole -d
(or running the debug script through the web interface]
This is not an issue of pi-hole but an issue on my network setup caused by pi-hole installation therefore I can't provide any debug.
Could you please tell me what pi-hole installation script does to the network and how I can restore back my network setup ? I see that all my network setup (bonding, wlan) is as before I mean the configuration files but the network doesn't work anymore. That means that configuration is now handled from some other configuration scripts that pi-hole installed and I can't find where and what.
Please help as I use this raspberry server for many things and I can't have it offline for long time.
Thank you
