Hello
Since i havn't got any answer in the german-board, i will try it here, mabe here are more peoples, who can help me. Sorry for my poor english, i hope you can understand, what i am trying to say…
Im a Newbie and have installed the Raspberry and Pi-hole. The DHCP-Server from my ISP-Router doesn't allow to give any Settings with it (only enable / disable and MAC-based IP reservations). So i want to use the build-in DHCP-Server from Pi-hole.
When i have installed Pi-hole, the Setup toke from the ISP-Router the static-DHCP-Adress IPV4 (192.168.1.120) but also a IPV6 Adress (2a02:1205:c694:.....), which is not a ULA, right?
If i will enable now the Pi-hole DHCP-Server (and he will provide all my Clients also with ULA IPV6 IPs) is this a Problem, that the Raspberry still have his old IPV6 Adress? Does the Raspberry also need an ULA-Adress?
Thanks a lot and best regards
Fred
