Hello,
I just installed pi-hole in a docker container and it works fine when this option is enabled: Respond only on interface eth0
However i read that it's potentially dangerous and i am not sure if my setup is safe or not. Pihole it's installed in my own local server. It's not a droplet or something. That server is behind a normal router and it's not directly accessible via the internet.
I will also install wireguard on that machine to be able to VPN into my local network when i'm away and will port forward the standard wireguard port .
Considering this setup, is it safe to have that option enabled? I don't have port 53 open from my router but i am not sure how DNS works in this regard. I am mostly thinking if by installing that Wireguard it will also make my pihole visible via the internet.
Any insight would be appreciated.
Thank you
